1996 Dodge Dakota Logo
Anonymous Posted on Apr 09, 2010
Dakota wont start
I have a 96 dakota wont start got fuil and spark even sprayed starting fluid in it and still wont start it cranks over but wont start new crank shaft sensor coil wires traced all the wires everything is good computer is good someone said it could be the starter solenoid didnt try it yet cause someone said if it was that it wouldnt crank over can anyone help
Abdul Rasheed
Level 3:
Master:
  • Master 567 Answers
  • Posted on May 20, 2021
Abdul Rasheed
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
181648
Points
1403
Try removing the spark plugs and squirt some oil into the cylinders. If it runs or there is signs of combustion when
using starting fluid, then do a compression test. Valves maybe stuck or leaking. piston rings broken. Wrongly set distributor or timing belt/chain.
Renaldo Fruean
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
Renaldo Fruean
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
634
Points
It wouldn't be the starer because the engine is cranking.
03chevy
Level 2:
New Friend:
  • Expert 79 Answers
  • Posted on Apr 09, 2010
03chevy
Expert
Level 2:
New Friend:
Answers
79
Questions
0
Helped
38990
Points
248
Your pickup coil could be the problem. not geting enough spark or sparking all the time
3answers
3.9 98 dakota won't fire replaced computor and coil what would you try next
Check distributor. Remove cap and examine components. There should be a rotor and a triggering device on the shaft which tells the computer when to fire. Make sure the shaft turns by having someone to crank it while you watch. If it doesn't turn your timing chain or belt is broken
2answers
97 gmc 1500 350 5.7 new fuel pump and filter it cranks over but wont start
Kelly, could be a few issues, security lock out, crank sensor, fuel pump fuse/relay, faulty new pump,faulty ignition switch, etc. Attached links may help you diagnose the crank no start issue you are having.
Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
96 98 Chevy pickup cranks but won start first steps
GM no start no fuel troubleshooting
No Start No Spark Cranks OK GMC Jimmy S10 Blazer
1helpful
96 chevy lumina cranks but wont start check it 4 fuel getting up to the rock have a new battery in it could this be the security system
very possible if you have a security light or anti theft light coming on flashing yes that's the problem is not check for spark anD fuel if you have spark try spraying starter fluid through the intake if it cranks then you may have a problem with a cam sensor
If you need further help, reach me via phone at https://www.6ya.com/expert/james_9c1b039055413ffa
1992 dodge dakota wont start
If no spark check out the wiring in ignition circuit along with your ecm which fires the plugs.
1helpful
2answers
My 2000 dodge dakota wont start. I replaced the battery and still wont start. The lights are strong and it turns but wont start. What could be wrong?
Two basics; fuel supply and ignition. Neither of these are difficult to check but for in-hand assistance, a service manual is a good investment and we like Haynes:
Dakota service
I have a 96 dodge dakota with a 3.9 V6 i have spark and fuel pressure but it wont fire at all i was told it could be the crank sensor
Always check for spark at the coil first,than see if its going to the spark plugs, I have had bad crank sensor and truck still started.But did you do a scan,get it scaned and see what codes it shows.
86 dodge dakota 3.9 wont start
Does it crank over and sound starnge? Could be a timing chain.
2helpful
1998 dodge dakota 4x4 5spd 3.9l-cfank but wont
Do you have spark?
Do you have fuel?
Which are you missing?
TIP.A quick check for spark.........give it a spray of starting fluid....if it runs....you've got spark.
No spark usually means......a bad coil or ignition module on the 3.9.
No fuel is usually caused by a bad fuel pump.
2answers
Not starting
Air/fuel/spark. check the 3, and then do a dummy test. I know , im not insulting you, but my dakota wont start if my gascap isnt screwed down all the way, it throws a sensor and it wont start. So just do all the dummy stuff you know has to be done to start it, put it in park, close all the doors, stuff like that, never know, could be something simple. if not, as above, Air/fuel/spark. need all 3 to start an engine.
2answers
Truck wont start
1.) spray engine starting fluid into air intake ---remove air filter if necessary.
2.) if ignition only on this spray, then seek bad fuel supply problem.
3.) if no ignition, check for spark.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
