Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Hoover h3030 Brushes do not spin,I have put in a new brush motor drive.
  • zoe10brandon Mar 23, 2008
    Hi Guru,
    Yes I replaced 20 , But it didn't come with the circuit board attatched .I think it might be the circuit board or they are suppose to have a reset switch.
  • librarian54 Apr 08, 2008
    the brushes will not spin.
    President:
  • 1,673 Answers
In thi picture, did you replace #20? It is what drives the brushes.
Posted on Mar 21, 2008
Hoover carpet cleaner brushes wont spin
First i would be checking for a mechanical restriction stopping the brushes from spinning like hair or similar wrapped around the brushes and jamming them, if all is clear it could be a belt broken or slipping, a stripped gear or an electrical fault, depends on what type of drive system the brushes on your particular vacuume cleaner uses. Hope this is helpful.
Aug 17, 2017 | Hoover Vacuums
Hello my Hoover works well except it is has gotten very, very loud it wasn't this loud before any suggestions?
Not knowing what the loud sound is, try to determine if it's coming from the spinning brushes or the motor. Those are the most likely problems.
Mar 25, 2016 | Hoover H3030 FloorMate SpinScrub 500...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Agility F6215-900 brushes won't spin
first it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Jul 31, 2009 | Vacuums
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Brushes won't spin
The power wire may be disconnected
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
Apr 21, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover spin scrub bristles not spinning
Hey, I am wondering is anyone watching over this site. I have seen many questions about brushes not spinning on the hoover vacs but now response except one back in April that said something about taking the bottom over off and checking something but the person wrote back asking how to take off the cover and got now response. I also can't figure out how to get the cover off. Mine is the F5906-900
Mar 12, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
