Question about Sony PlayStation Portable (PSP) Console
PSP internet my internet wont work, wen i scan for a network i find my wun but it says in the security colum 'no support' and i cant select it i tried doing it manually and it still didnt work i think the suceurity for my router uses a different format so my psp cant read it. How can i fix this problem or how can i change my security type?
  • dEaThBoY Mar 21, 2008
    no the point is that i cant select it it is in grey and no security means my psp cannot read the router security code, most likely the router does not use WEP
  • 84 Answers
Try not using so much security on your router.
use WEP , WPA-TKIP , WPA-AES
Posted on Mar 21, 2008
    Problem Solver:
  • 4 Answers
If you use secruity on your network you will have to enter the password
Posted on Mar 19, 2008
6ya staff
SOURCE:
What i need to do to connect my psp for internet
You will need a wireless router in order to connect the PSP to the internet
  • With your Psp turned on go to the "Settings" in the menu (scroll to the left)
  • Scroll all the way down until you have reached "Network Settings" and click the "X" button to enter
  • Select "Infrastructure Mode" and hit "X"
  • Select "New Connection" and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose "Scan" and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • When the PSP finishes scanning you will probably have a few different wifi connections. SSID is the name of the connection, the Security column tells you whether or not the connection is password protected, and the last one is the signal strength the higher the better
  • If you want to borrow your neighbors unprotected wifi select a connection with "None" in the security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • Now the Psp will confirm your settings proceed by pressing left on the d-pad and save your settings
  • Now test your connection if you are able to connect, awesome. If you were not able to connect try doing the settings again
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached "Network" and go down to "Internet Browser" and hit "X"
  • Your browser will appear, select the little square box to enter the web address, play around with the different options. Have fun with your PSP online
Dec 16, 2010 | Sony PlayStation Portable (PSP) Console
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
Cant connect the internet
  • With your Psp turned on go to the “Settings” in the menu (scroll to the left)
  • Scroll all the way down until you have reached “Network Settings” and click the “X” button to enter
  • Select “Infrastructure Mode” and hit “X”
  • Select “New Connection” and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose “Scan” and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • If you want to borrow your neighbors unprotected wifi select a connection with “None” in the Security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached “Network” and go down to “Internet Browser” and hit “X”
Oct 22, 2009 | Sony PlayStation Portable (PSP) Console
Dont no how to connect the internet to a psp go
Oct 22, 2009 | Sony PlayStation Portable (PSP) Slim...
WPA internet wont work on my psp
The PSP does not support WPA2. It does however support WPA.
Aug 12, 2009 | Sony PlayStation Portable (PSP) Console
Cant find aoss button
There is no aoss button on a psp its on a seperate device the you have to buy that allows you to watch tv on your psp.You need internet to get online with a router but you could see if you can get connections from your neighbors.To try to get online got to network settings,infrastucture mode,new connection,scan,and if anthing pops up you could get connected tp it as long as it doesnt have a code if the security says none you can get on.next press the right arrow after you selected your internet,then click none,easy,click right,right,then press x.
Aug 11, 2009 | Sony PlayStation Portable (PSP) Console
How can i get my internet up and going on my psp
First off, you need to get to the main menu from wherever you are on your PSP. You can do that by pressing the Home button, a tiny button just to the lower left of the screen.
Now you'll want to move left (pressing the "<" button) until you get to Settings, then down (pressing the "V" button) until you get to Network Settings:
select Infrastructure Mode
select new connection
and give a name to the connection
When you're done struggling to enter your selected name :-) move to the green "Enter" box and press the "X" button. Now you'll be ready for the big important step: a Network Scan:
psp-network-scan.pngso now it will scan for the available network and then show u the network select ur network psp-select-access-point.png
after selecting the name it will ask u for security settings select the security settings according to your router and if it asks enter the router security key and press next and then save settings now try and access the net on psp
Jul 11, 2009 | Sony PlayStation Portable (PSP) Console
Psp how to get on to the internet using wifi
manfiodhslfksdhklfdnsklcvnsdklvnklscvnklscnvklscnvlksdnvklsdnvskld
Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
Problems with my connection
your PSPs are attempting to connect to the net, via a wireless connection device. they are timing out for several reasons.
1:- cannot locate or connect to server.
2:- cannot connect or failed to connect to router or modem.
3:- your PSP is firmware version 1.50 ( this does not support a web Browser )
4:- the firewall if applicable, needs to allow the psp access as a trusted device on the network.
These are a few reasons, why your psp will not connect.
There are others, but these are quite significant.
hope this helps any of you.
Mike @ Compurepair.
information supplied by, 13 year old son ( PSP Addict AKA Rabbit )
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
Psp no connection to internet
Why can't I connect to the internet on my psp I tried over & over nothing it says the connection to the acces point has timed out..
i still can't connect even with wireless router
Jan 27, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
