Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
Error- no ink cartridges
The screne is showing no ink cartridges, open ink cover and set the ink cartridge. I just replaced the ink cartridges.
  • 6 more comments
  • Lazydogsbody May 08, 2008
    I have inserted new carts and the screen says ink levels full the suddenly says no ink carts.......HELP Please........Ian
  • bjgriff May 28, 2008
    Have same problem!!!!! no ink cartridges......need it up and running soon or it's out the window.
    Brian
  • hendrikbree Jun 18, 2008
    I have the same problem as described above.
  • wmena Oct 25, 2008
    I also have the same problem. Says no ink cartridges.... even after putting in new ones.
  • kitty JJ Nov 06, 2008
    have always used discount cartridges with NO problems at all. NOW all of a sudden it says NO ink cartridges at all and I just replaced the empty one, the rest are real EPson catridges, and it will NOT recgonize any of them...
  • Anonymous Nov 09, 2008
    I have the save problem. My printer is about 1 1/2 old. Used after market cartridges with any out any problems. Untill this last time when I went to replace the blk cartridge. Bingo----got error code no ink cardridge and suggested I reset the cartridges. I have trided everythign and read and reread everything on the net. No solutions to fix this problem. This is my thoughts on the subjest. Take it for want its worth. I think epson has it programed to shout down when u use after market cartridges for along period of time. The reason I think this, there is so many out there that has this problem. And it comes up right after u change cartridges. Good Luck.
    Ed in
    colorado
  • casalecci Jan 02, 2009
    same problem - printer has worked fine on all sorts of cartridges, yet over the weekend, I replaced an empty one with another from one of my suppliers and "no ink cartridges" message, so, I replaced all the cartridges with new ones all of which were of the same make, but I still get the "no ink cartridge" message.
    Any solution would be gratefully received
    Thanks
  • Titanic2 Feb 07, 2009
    Replaced one OEM cartridge. I have only used OEM cartridges in the last 2 years. Same message as above - printer unusable. Do I now buy a new (non -Epson) printer???. I worked for IBM for 25 years - in the early days. This was the sort of marketing ploy that they thrived on, until they fell by the wa
    yside.
    Do I now have to buy 6 Epson manufactured cartridges to get the printer working again - or just move to another manufacturer
  • 1,218 Answers
1. Set all the printer cartridge both black and color cartridge (including the empty one)
2. Right click on printer driver properties
3. Click Maintenance tab
4. Click on Ink Cartridge Setting mark
5. In pop up menu, select the cartridge which has ink inside (black only or color only). or check the following information..
http://www.fixya.com/support/t2689003-set_ink_cartridge_invalid_ink_cartridge
Posted on Sep 06, 2010
    President:
  • 8,637 Answers
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Posted on Jul 20, 2010
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
It says i have a automatic alignment problem it shows i have ink i have'nt changed the ink since i brought the printer.
It could be that the cartridges are not seated properly in the cartridge carrier or the encoder strip got unseated from its position. Please follow steps below to fix the problem:
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. While the printer cover is open, check the cartridge area for a loose encoder strip (transparent strip).
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, re-insert one cartridge first.
  7. Close printer and check for any errors.
  8. If no error appears, reinsert your other cartridge.
  9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 25, 2011 | Lexmark Z2420 Printer
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I've got a epson r320 it's about 5yrs old it does not get used very much. Today I replaced couple ink cartridges, shut it off restarted it and the new cartridges is regestering as half full and even empty....
Q:
I replaced an ink cartridge and my printer still shows that ink is expended. What should I do?
A:
If you have just installed a new cartridge and you are still seeing an ink related error, the cartridge may be incorrectly installed. Follow these steps to reinstall the cartridge.
Make sure the printer is turned on, then open the printer cover.
Do one of the following:
If the red error light is on, press the Maintenance button.
If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
Open the cartridge cover.
Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
Close the ink cartridge cover.
Press OK and close the printer cover.
The printer begins charging the ink delivery system.
When you see a message that charging is complete (after about a minute), press OK.
SRC: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1006416496.1302793816@@@@&BV_EngineID=ccekadfdfkjgijhcfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=47541&prodoid=47915738&foid=130809&cat=30942&subcat=30923
Apr 14, 2011 | Epson Office Equipment & Supplies
Tow red signal
  1. Make sure the printer is turned on, then open the printer cover.
  2. Do one of the following:
    • If the red error light is on, press the Maintenance button.
    • If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
  3. You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
  4. Open the cartridge cover.
  5. Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
  6. Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
  7. Close the ink cartridge cover.
  8. Press OK and close the printer cover.
  9. When you see a message that charging is complete (after about a minute), press OK.
Dec 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Ink cartridges cannot be recognized in canon printer
    Hello!
    Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
    If that doesn't work, one of your cartridges (sadly) needs to be replaced.
    Apr 15, 2009 | Canon PIXMA iP1300 Printer
    First cartridge change
    Hi
    1. Make sure the printer is powered on, and not printing.
    2. Open the printer cover.
    3. Do one of the following:
    3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
    3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
    3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
    4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
    5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
    6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
    7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
    8. If you need to replace another ink cartridge, repeat steps 5-7 above.
    9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
    10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
    Aug 02, 2008 | Epson Stylus Photo R300 InkJet Printer
    My Epsn Stylus PHOTO R300 says I need to replace an ink catridge however it does not tell me which one is out of ink. How do I find out which one to buy?
    If an ink cartridge is empty, the red error light will remain solid. You can check the status of the of the ink cartridges by looking at the icons on the control panel. Press the down arrow button to scroll down to MORE OPTIONS. The level of ink will be shown on the screen and the ink that will be out will have cross on it.
    Please follow the steps below to replace one or more cartridges.
    ***NOTE***
    -You cannot print if any ink cartridge is expended.
    -Leave the empty cartridge installed in the printer until you have obtained a replacement.
    -To ensure good results on your printouts, we recommend using Genuine Epson Ink cartridges. Epson does not recommend the use of refilled inks or 3rd party ink cartridges.
    Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
    May 23, 2008 | Epson Stylus Photo R200 InkJet Printer
    Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
    732 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
