Question about Canon PIXMA MP460 All-In-One InkJet Printer
Paper jam i have had an MP460 for 2 months and it screws the paper in on an angle and ses it has a paper jam and other times it just wont take the paper through! we have cleaned it like the instructions said to but it is still doing it what do i do??
This happened to me awhile back while I was making a Christmas present for a friend. What ended up happening was some little object (mine being a little plastic piece from my iPod) had been set on the top of the scanner part and somehow swept into where the paper is fed into the printer. I took the printer and with some help turned it upside down, the piece came out and everything worked just as new. So I suggest before taking it to get fixed or before buying a new printer just make sure there is nothing in the paper shoot! =] good luck!
Posted on Apr 09, 2008
    Genius:
  • 3,587 Answers
I'd suggest that you use only one thickness of paper, and also clean the rollers with denatured alcohol.
Posted on Mar 18, 2008
SOURCE:
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
When going to print paper is pulled in angled and jams thanks
i do not know the model of the printer that you have, but the most common problem is that you have something stuck in the area where the paper is not being pulled in. You might have a small piece of paper jammed in there or some foreign object. It is also possible your sensor is jammed and the paper is hitting it.
Lastly, if you have 2 pickup rollers (depends on the printer that you have), one could be worn out.
thanks adi
May 07, 2009 | Office Equipment & Supplies
Why does the paper jam inside the printer
When it Jams, I like you to open the printer, does anything BLOCK the printers path, also are you using recyled paper or paper that has gone thru the Printer then re-used again ? Also is the carriage movig back and forth while it jams ?
Mar 08, 2009 | Epson Stylus Photo R320 InkJet Printer
Every time I try to print the paper jams.
check the pickup roller, make sure there is nothing preventing the paper from loading stright.
if all of the paper path are clear, then you will have to get a maint. kit to replace the roller themselves.
Mar 05, 2009 | HP PSC 2175 All-In-One InkJet Printer
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Paper going thru at an angle and jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Constant Paper Jam
I have the accordion paper jam problem as well, almost all the printout got jammed. So I opened the back panel and unscrew 2 screws and take out the part with the small plastic roller and clean those. Then I also see a rubber roller on the ceiling of that area and cleaned and rubbed them with a damp cloth and rolled them several times. Now it's been 2 weeks of jam free printing! Back to being happy customer...
Jul 21, 2008 | Brother MFC-7820N Laser Printer
Paper jams/ printing blank
Thoroughly check for very small foreign objects in your printer, and check both behind in paper feeder area and inside the unit. Jams can be tiny pieces of paper than have gotten in or torn off paper fed in at slight angle but you may not have noticed. Service you printheads and rollers both manually with solution and cotton buds (q tips) and then see if your ink may be low or out, blocked printheads will obstruct ink from flowing at all. So will damaged printhead points on cartridge, signalling replacement time.
Aug 14, 2007 | HP PSC 1215 All-In-One InkJet Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
