Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Rear projection Toshiba--greenish picture, but works okay with DVD
6 year old rear projection, suddenly has no color , looks black and white but greenish. works okay with DVD and Xbox!
I HAD exactly the same problem. It is a connection problem and not a Sony problem. The fact that other sources show a good picture is the critical clue. I found a loose connection on the rear of my Dish Network receiver. I hope this works for you. It did for me.
Posted on Apr 24, 2008
  • 84 Answers
Try removing ac power and plug in power again sometimes helps
Posted on Mar 23, 2008
SOURCE:
Color looks white washed!!!
there are in the older rear projection sets lens for those that do not use a lamp for a light source.
In the older sets there are three large black lens that can be seen and reached with the rear cover off---if there clean them as they are the light source in those sets and if dusty picture will look dull and darker than it once did.
If in doubt shoot me a model number.
Dec 05, 2012 | Toshiba Televison & Video
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
Mar 27, 2012 | Toshiba 50H81 50" Rear Projection...
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Hitachi loses color
you are losing one of your color tubes for it to be goiing to black and white.
Jan 27, 2009 | Toshiba 57H82 57" Rear Projection...
Picture with red 3-D effect
IC8001, STK392-560 seems defective, its convergence output IC.
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
