Question about Cell Phones
My touch pad will not work was on the charger and just quit cant check messages
    Problem Solver:
  • 7 Answers
Try repairing or changing the touch pad because chances are the curcits for the touch pad is fired this tend to happen when the phone is charged over and over so in the future try to charge the phone when the battery is nearly dead or charged at night only or at day only and also keep in mind the number of hours the battery takes to full charge if you change the touch pad and the problem persist email me [email protected]
Posted on Mar 18, 2008
6ya staff
SOURCE:
What does this message mean on my stove: EO14 and beeping
The E0 14 error probably means that the control panel (clock) is not able to communicate with the touch pad. Trip the circuit breaker to off for at least 60 seconds. If the error recurs, you need to check the wiring between the control panel and the touch pad. Make sure that the wiring harness is tightly connected on both side. Check for any breaks in the wires. If there is no obvious problem with the wires, replace the touch pad.
Check the full model number of the double oven. The parts may be available here: http://www.searspartsdirect.com/ .
I hope this helps.
Nov 27, 2014 | Kenmore 49069 Electric Double Oven
When i put my charger my mouse pad is not working
  1. It might be due to touch-pad drivers.
  2. Use a system utility tool like Reginout to fix windows registry errors.
  3. Reinstalll Touch pad drivers.
  4. If the problem still occurs then Its due to charger. Change the charger that you are using. Use a charger whom Power(Watt) is less. Hope problem is solved.
Apr 23, 2012 | Toshiba Computers & Internet
When i put the charger in my lenovo s100 pc my mouse pad is not work
While charging my laptop , mouse pointer cant work and while it. why?
Hi avinamit,
I saw your question and I think I can help you with your concern.
you mentioned that when you connect your charger/Adaptor tp you laptop that the touchpad will not respond or move, I believe that your machine may be experiencing a small amount of ground from the adaptor to the touchpad, here is what we need to do,
  • First we need to turn your Laptop OFF
  • Once turned Off, remove the battery from your Laptop and unhook/remove the AC adapter/Charger as well.
  • Once the Battery and the Adapter is remove from the system, press and hold down the power button for 10-15 seconds this will drain any power left in the system, by doing this we will be starting the machine up with a new set of power coming from the Charger.
  • Once the power is drained is done connect the Adapter back to the machine and the battery try to power your system ON and check if the touch pad will work now with the adapter connected to your Laptop.
this may help you with your concern about the touch pad not responding when the charger is conencted, but still if the issue still exists then most probably the machine is grounded from the charger to the motherboard thus causing malfunction to some of your system devices.
thanks I hope this helps.
Apr 08, 2011 | Compaq Presario 700 470024-192 Notebook
Touch pad quit working recently.
Please visit Asus website and download the touch pad driver and manual for your computer mode.
http://www.asus.com/entryflash.htm
Jun 03, 2010 | ASUS Eee PC 1000H Laptop
Mouse quit working on my Lap Top it is a Aspire
First of all check whether the touch pad is lock (Fn+F7(?)). If you use an external mouse/ usb mouse, check usb cable connection, as long as you didn't drop it on the floor it should be ok. If the built in touch pad doesn't work, could be caused by ribbon cable connectivity that has dirt or moist. To fix it need to open the upper case
Apr 08, 2010 | Computers & Internet
TOUCH PAD ON MY LG VU QUIT WORKING
You need to replace touch pad. Parts cost around $25. Fairly easy to replace. Once you see it you will know how to replace, Go on ebay and put in lg vu touch screen and you should pull up parts for your phone. Or just google lg vu replacement touch.
May 15, 2009 | LG Vu Cellular Phone
Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Touch pads or heat sensors screwed
If you have auto keylock on try turning it off.
Aug 19, 2008 | Sony Ericsson K850i Mobile Phone
My touuch pad on my lg chocolate wont work was on the charger and just quit cant check messages
the board must be fried if it is you need to replace it with a new touch pad and in the future try and charge your phone less the more you charge your phone the greater the chances are of your curcuits becoming fried is problem is not solved when you change the touch pad email me [email protected]
Mar 18, 2008 | Cell Phones
Cell Phones Logo
131 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
