Question about RCA TruFlat 27F520T 27" TV
Please help, RCA Service Menu TruFlat 20F420T
I went into the service menu and cannot get it to exit... The screen size is to big and I accidentally hit the 'Notepad' button which I noticed defaulted some settings... Could you please guide me in how to get out of service menu / or reset some of the settings back to the way they were.
          Thanks a lot.. Im scared that I broke it please get back to me soon
                           Chris
SOURCE: rca 20F420T
Hi, I just had the same issue a few days ago. When you are using the universal remote, make sure the "tv" button is not blinking. Just press it and then you will be able to use the volume up and down and the channel up and down. I was able to use a universal remote, and unlock the fpa. Good luck!
Posted on Sep 26, 2007
maklean
  • 1665 Answers
SOURCE: Service Menu RCA HD56W58 56" TV
http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
Posted on Jan 28, 2008
  • 36 Answers
SOURCE: How to exit service menu
Try this
Use the CLEAR button / long press on the MENU button to toggle between user and svc menu. Press EXIT button to exit svc menu.
Posted on Apr 17, 2009
  • 72 Answers
SOURCE: my RCA TruFlat Model No. 20F420T shuts off at
HI,,
ITS NOT PROBLEM WITH TV TIMER...
ITS PRBLEM WITH TV AC TRANSFORMER WHICH IS INSIDE,,
ONE OF THE POSITIVE COIL INSIDE TRANSFORMER ITS SHORTING,,
APPROACH TV TECHNICIAN...
Posted on Nov 11, 2009
  • 12 Answers
SOURCE: I have a RCA Truflat
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Posted on Feb 18, 2011
I would like to access the service menu on my RCA Truflat 27F554T tv but I have no idea how. I have looked everywhere and all the methods I have tried for RCA tvs did nothing.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 03, 2015 | RCA Televison & Video
20FP420T FP lock on and can't select input no remote?
Do you mean the 20F420T? RCA doesn't have a 20FP420T as far as I can tell.
Unfortunately, you can't turn off the Front Panel (child lock) without a remote. All of the front panel Power button to turn off the set but not to turn it on. You need a remote that matches the Menu function. Press Menu, then use the Ch+/Ch- buttons to select Preferences. Press OK then press Ch+/Ch- to highlight FPA lock. Use the Vol+/Vol- buttons to toggle the lock function on or off. (Off lets the front panel work normally) Then press Menu repeatedly to exit the menus. A substitute remote can be obtained here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=12994577706920 . This is guaranteed to work with the 20F420T . Most universal remotes should also work as long as they were programmed after 2006.
The manual for the 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . Fill in the drop down menus for 20" and the model.
I hope this helps.
Mar 07, 2011 | RCA 20F420T 20" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Feb 18, 2011 | RCA 20F420T 20" TV
How to remove child locks
If you have lost or forgotten the code, the default factory password is 0000. This should still work even if you have set another password and forgotten. You should also deactivate the lock fully from the menu if you no longer wish to use it or activated it accidentally.
Disabling the child lock (and/or other locks):
(This can be done from the remote or the buttons on the front of the TV)
1. Press MENU to open the main menu.
2. Press CH+ or CH- to highlight PREFERENCES.
3. Press OK to enter the PREFERENCES menu.
4. Press CH+ or CH- to highlight FPA Lock (Front Panel lock) .
5. Press VOL+ or VOL- to switch the lock on or off
6. Press MENU repeatedly to exit the menu
The menu will disappear if no buttons are pressed on the remote for several seconds.
Please let me know if you need further assistance.
Regards,
BElectric.
Jan 31, 2011 | RCA TruFlat 27F520T 27" TV
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
menu or the menu will automatically
disappear within a few seconds if no
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
FPA LOCK
Using your remote, go to Menu, Preferences, FPA Lock and change it to OFF.
If you don't have the remote, you'll need to program a universal one that has a Menu button to access the menu.
Jul 09, 2009 | RCA TruFlat 27F520T 27" TV
FPA LOCK IS ON AND I HAVE NO REMOTE FOR THE TELEVISION,,, HOW CAN I FIX THIS?
You will need an RCA Remote or Universal (RCA) may work. Once the Front Panel Assy. is locked the TV will only Power on with a remote. Call an Authorized RCA warranty service center, and offer to leave a deposit for the use of the remote. Power the TV on with the remote. Press Menu on remote. Press CH- (down) button on remote to highlight "Preferences". Press OK button to open menu. Press CH-(down) button to highlight "FPA Lock". Press Vol.+ button to turn off FPA Lock.Press Menu button to return to Main Menu. Press Menu button again to clear On Screen Display.
Dec 23, 2008 | RCA 20F420T 20" TV
Try this
Mar 18, 2008 | RCA 20F420T 20" TV
RCA TruFlat TV
Be happy to explain how I fixed the problem.......please send $40.00 and I will forward the solution!!!!
Mar 03, 2008 | RCA Televison & Video
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
RCA TruFlat  27F520T 27" TV Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
