Question about Vacuums
Filter Queen Assembly
I received a disassembled Model 700 Filter Queen Vacuum. I'm looking for a schematic showing the rubber gasket assembly where the motor sits in the bottom housing base. I have 1 heavy rubber gasket plus a lighter one with metal screen & round filter paper. Each one by itself will assemble together but not both. Do both of these gaskets belong here? If so who do they go together? Dave H
  • bd7buck May 11, 2010
    the man wanted to know what or if that and where the other big thick gasket goes that does'nt have the screen in it
Talked to a local tech & he helped me out. DH
Posted on Mar 23, 2008
    President:
  • 1,673 Answers
On the rubber piece, there is a groove on the inside edge for the screen first, then the filter. Just have to work them into that slot. Then put over the bottom housing. The round paper filter is put on over the tank, then the top unit sits on that. These filters will keep dust out of the motor and head asm.
Posted on Mar 18, 2008
Part diagram of the blower fan assembly
Contact Filter Queen directly and inquire whether they have a part diagram for an unidentified 40-year-old blower fan assembly.
Dec 30, 2017 | Filter Queen Vacuums
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
Parts schematic for riccar 8920 vacuum
I am looking for a new motor for my 8920 Ricaar Vacuum. All else works fine.
Jul 13, 2012 | Riccar Vacuums
Power switch does not go into high how do we get it out?
I believe it has a foam surround under the top that has the screws which hold the motor assembly on. Also look under the top exhaust connection on the top of the vacuum.
Oct 07, 2009 | Filter Queen Majestic Canister Vacuum
Broken belt on filter queen majestic power nozzle
Try removing the roller assembly again, and check the end bearing pieces are the correct way around. Often they have 2 or more settings.
Check all debris is removed from location slots, and see if the roller is actually going into position before the cover is attatched.
Dec 30, 2008 | Filter Queen Majestic Canister Vacuum
Carbon brush type
Zarico the brushes will be very difficult to find on that particular unit. unfortunatly the only way to resolve this issue is to update the motor itself. i can help you find a cheep alternative. being as all filter queens are on the same design you can replace the motor itself or update the entire top motor portion. here are a few links to try and help you out with your problem. http://cgi.ebay.com/FILTER-QUEEN-MAJESTIC-LTD-ED-MOTOR-UNIT-ONLY-PERFECT_W0QQitemZ390011060044QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item390011060044&_trksid=p3286.c0.m14&_trkparms=72%3A570%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
http://cgi.ebay.com/FILTER-QUEEN-VACUUM-MOTOR_W0QQitemZ350131357431QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item350131357431&_trksid=p3286.c0.m14&_trkparms=72%3A570%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
http://www.totalvac.com/accessory/parts/L-115750C.html
http://www.totalvac.com/accessory/parts/FQ-3309C.html
Hopethis helps ya out bud
Nov 02, 2008 | Filter Queen Majestic Canister Vacuum
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Disassembly for repair
sometimes the brush assembly melts because of the way it was designed, could be broke, but u have to take it out and look at the assembly first, turbine is powered through air suction
Jan 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Filter Queen Vacuum Just Stopped
Could be a bad switch or a bad cord would be the first things to check.
Jan 04, 2008 | Filter Queen Majestic Canister Vacuum
Vacuums Logo
337 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
