Question about Refrigerators
Fridge Problem My fridge keeps turning off intermittently. It might be alright and stay on for a few days then it will just turn off. There is a reset button on the back which turns it back on again. I thought it might have been from the door not closing properly and maybe the motor had some sort of shut-off that you could then reset with the button on the back, but it will also turn off after it has been running for a few days and not opened. I have looked at the seal and it looks fine. Any help you could give me would be much appreciated. Thanks
  • 26 Answers
1. Clean the condenser coil.
2. Have the refrigerant pressure checked
3. If your refrig. has an autodefrost timer it may be failing.
4. The sealed compressor unit may be going.
hope these help
Posted on Mar 18, 2008
Zanussi fridge freezer
Sounds like a bad solder joint causing intermittent power issues...
Jun 19, 2016 | Zanussi Refrigerators
LG Refrigerator model LFC20740ST Freezer is fine, but Refrigerator is not cold.
Try adjusting the thermostat knob up a bit, it should be near the leds, maybe under a cover. Seveen years is not very old but where your health might be at risk from bacteria maybe you might be justified in looking at a new machine. I refuse to call in repair people any more, once something breaks it seems to become a habit, if electrical items cna be said to have habits.
Maybe a new thermostat /seitch might cure the problem
Jun 18, 2015 | LG Refrigerators
Freezer keeps building up ice on the condenser i think, and after a few day sitting the bottom part of the freezer freezes and the rest dont
I'm not sure what system you have but typically there is a defrost timer on the back of the fridge. Often you can barely detect where it is, as only the stem sticks out.
What worries me is the amount of moisture in your fridge. You did not indicate how long to make the build up, check your seals carefully with a dollar bill.
Sep 02, 2013 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Currently have a Kenmore 26 Porcelain plus. Fridge keeps beeping intermittently and ''warn'' and ''check food'' lights stay on. Both fridge and freezer seem to be working. Any suggestions?
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good
Jul 30, 2010 | Kenmore Refrigerators
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Not cold enough. freezer works but fridge wont stay cold. i can shut it off for a day and it will work for two more. after that it quits again.
It you have a frost free fridge, then what is happening is that either the defrost element or the thermostat is faulty, causing ice to build up and block off cold air circulation to the fridge. Sometimes the frost builds up around the circulation fan and ceases it up.
That is why when you turn the fridge off for a day, the frost melts and drains out the back of your fridge and so the fridge works ok for a few days until the frost build up again.
Another thing to watch out for is the defrost timer. Sometimes they fail and stick on one cycle and dont advance through. pull your fridge out. The timer is located in the back near the compressor. There is normally a small dial on it. With the fridge turned off, you can twist the dial clockwise and you will hear the timer mechanism click through the different cycles. Make small ink mark on the timer dial. Say at 12 oclock. Turn fridge on. Chech the fridge every couple of hours and see if the mark advances through and does not get stuck in one position for lengthy periods of time. The defrost cycle should normally be around 8 hours and it repeats again.
Let me know if you need more help with the defrost element or thermostat. But it is best to get an experienced repairer to change those.
Good luck
Ash
Oct 31, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
