Question about Refrigerators
Clicking & Electrical Smell
I'm suddenly hearing a clicking noise and there is a burnt, electrical smell. Both the freezer and refrigerator seem to be cooling properly up to this point.
  • pegboheen Mar 19, 2009
    Heard some strange clicking noises, went to investigate and discovered an unfamiliar burned smell, like plastic coming from the refrigerator.  We are worried that it may be dangerous, especially since other Maytag performas have been recalled for starting fires.
  • Anonymous Mar 16, 2014
    my fridge smells like burnt rubber and is making a clicking noise
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Sounds like the relay on the compressor. Although this can just blow and is common you may find that the compressor windings have gone short circuit, ( in which case the compressor is u/s and will need replacing). The relay can usually be found under the cap where the cables attach to the compressor. some are push fit ( over 3 pins on the compressor normally) and some just look like a bottle cap with 3 wires coming off (which attach to the 3 pins on the compressor). A meter may show the short but there is very little resistance on the windings in the first place. There are lots of generic relays that will fit. Make sure you note what wires comes of where before getting a replacement, most euronic stores will carry them as do companies like SEME in the uk
Posted on Mar 18, 2008
Gnev120w Made a noise, now not freezing.
the fan only controls air circulation. not the function of the motor. sounds like ur fridge is stuck in the defrost mode? check ur cold control thermostat with a multi meter for continuity. the fan does not run while in defrost mode, u can manually check ur defrost timer in the fridge by sticking a small screwdriver into the hole underneath it, and turn clockwise till u hear a click u should hear the fan and compressor come on if not turn 1 more click?
Mar 19, 2015 | Beko Refrigerators
Quiet wash 1 doesn't drain
the pump could be siezed or blocked. burnt rubber smell from the drive belt. look under the machine and try to turn the pump pulley
Apr 17, 2014 | Whirlpool WED5600XW - 27", 7.4 Cu Ft, He...
Electrical burnt smell
If you had a short in the starter motor windings and held the key, you'd get a click and a burning smell. That would be the insulation burning off the electrical windings. There's a 40-amp max fuse in this circuit.
Jul 21, 2017 | 1995 Chevrolet K1500
My electric Oven keeps tripping the breaker off as well as making a popping noise while doing it and leaving a burning smell. When i turn the knobs to the burner on i hear a clicking noise coming from the...
Hi. YES you most definately have a short. The burning smell is coming from either the wire arcing and thus producing ozone and heat, or the insulation on the wire is being burnt. Take the back off the control unit to expose the wires and see if you can see where the wiring is burnt. It could be a loose connection, or something more serious.
If in doubt, call a professional repairman to check it out.
Earl Marshall
Norse Tool/Equipment Repairs
Sep 22, 2011 | GE JKP15 Electric Single Oven
My bottom freezer refrig. Kenmore 596.72214200 - suddenly smelled weird burning smell from back of frig., hear occasional clicking sounds. Everything seems to be working. Smell seems to happen when...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | Whirlpool Refrigerators
Noticed smell in kitchen yesterday whcih made me think of an electrical issue or motor problem. Wasn't sure where smell was originating from This morning I am hearing a clicking sound from my Whirlpool...
the start device is cooked.pull out the machine and unplug it,remove the bottom panel in the rear and you'll see the compressor,on the side of it you'll see the start device,remove the clip and slide it off the compressor.read the instructions with the new device and install it.if you open the fridge door,look up on the right side wall near the ceiling you'll see the full model number,you need that to get the correct part,you can send it to me or give it to your parts store.the same thing happened to me but i was lucky i had the part in my van,good luck
Jan 23, 2011 | Whirlpool ED5LHAXW Side by Side...
Burnt electrical smell coming from refrigerator
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Burning Smell
sounds like the motor is fried or seized up, which would explain that smell.
Feb 17, 2008 | Refrigerators
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
