Question about Intel (SL5TL) Pentium 4, 2 GHz Processor
Processor fan why is it that when i change the processor fan of mother board p4 socket 478, my unit indicates an error of shutting down after 5 seconds
    Scholar:
  • 101 Answers
Maybe you have not put the correct fan on and it has shut down to protect itself. Processors overhead catastrophically in a matter of seconds. Also did you connect the fan to a power supply on the motherboard.
Posted on Mar 22, 2008
SOURCE:
Can I use P4 478 processor in K8V-MX mother board
You can not use intel ,It is a athlon platform Mother board.
Follow the link, and you can know every thing from here.Just click here.
Hope it will help you.
Regard's
Shibuda.
Dec 31, 2010 | ASUS K8V-MX Motherboard
Can I use a Intel P4 HT 2.6 GHZ Socket 478 PC CPU Processor SL6WH with this mother board
Unfortunately you would not be able to use it. Even though it has the same socket platform which is 478, the maximum FSB that the Motherboard can handle would be 500Mhz. The processors that you want to use has an FSB of 800Mhz. You can always try but there would be no guarantee for success, even if it does work, stability would not be achieved.
Hope this helps.
Jun 22, 2010 | ASUS P4GE-MX Motherboard
I could use a diagram of the mother board for a Pentium 4 2.4 Ghz processor. I picked one up second hand to replace my old processor
If your processor 2.4 Ghz HT you need socket 478 motherboard,System bus 800.without HT you need 533 FSB Motherboard.You can buy easily.Where you live? I do not know.China are available made 478 PIN mother board.
Mar 18, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Processor complaint
The manufacturer site states:
Socket 478 supports the Intel Pentium 4 processor up to 533MHz FSB
So as long as you get a Socket 478 type P4 processor with a 533MHz FSB or less, it should work.
Source: http://www.mercury-pc.com/product-detail.php?productid=333#
Feb 10, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
P4 ugrade required
Sadly you wont find any 1066Mhz FSB processors for the Socket 478. The best you can find is the 3.4Ghz with 800Mhz FSB. It might be cheaper and also better value for you to get a Socket 775 based motherboard and Core2 Duo processor. The value range E2160/2180 processors or the E4300/4400 processors have been tested to be even faster than the Socket 775 Pentium Dual 3.4Ghz and they also use less power.
An article on socket 478 for you http://www.xbitlabs.com/news/cpu/display/20040123103754.html
Dec 02, 2007 | Intel P4 Socket-478 Original CPU Cooling...
Gigabyte mother board
hi reason y it wouldn't start is because the 2 is not compatible, what u can do is get a Intel P4 not a celeronD check the socket size and make sure that it correspond with the board that u have. The board that u have uses a 478 socket size so u need to get a processor with the same socket size ok... that should do the trick
Nov 23, 2007 | Intel Celeron D 330 2.66G CPU...
Motherboard needs cpu
server mother boards are very fast and performance is really good. there is no problem using it as a home pc. you can use 478 socket processor
Oct 02, 2007 | Intel Motherboard
Msi 654e max atx mother board
If your manual states a max of 2.2GHZ then, take it as that, when your board was made the bios and bus speeds would be set at the maximum to run a 2.2GHZ, not a 3GHZ, also the heat sink and fan may not be enough to cool the processor. The only way that a 3GHZ would run was if you updated the bios and personally i would not recommend it. You would be better advised updating the board and processor as a package ot fitting more memory if the pc is not used for gaming or high end video editing.
Apr 19, 2007 | MSI 645E Max Motherboard
Intel (SL5TL) Pentium 4, 2 GHz Processor Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
