Question about Harman Kardon AVR 130 Receiver
Channel out. i own a HK 130 and my left front channel is out. Im using optical but does not respond to anything, all it will do is crackle a little..
    Problem Solver:
  • 16 Answers
The DSP board is defective. You need help from a HK tech
Posted on May 24, 2008
Keeps blowing speakers on left front channel
What exactly do you mean by "middle volume settings"? Where is the volume control physically, where are the channel levels set and what is the crossover point? After the crackling appears , do you switch speakers to the right channel to see if speakers are actually damaged or if the receiver is producing the distortion?
Jan 22, 2014 | Pioneer VSX520 Receiver
Bad left channel on hk 3375
does it crackle or make no sound from left
Mar 07, 2013 | Harman Kardon HK 3375 Receiver
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
I have a harman kardon AVR 132 and have just purchased a Samsung UA55D7000. I am running HDMI from the sammy to my ps3 for video and then an optical cable from the ps3 to my HK for audio and im having...
Hi, You might want to run your ps3's hdmi into your hk, as I'm sure it has hdmi inputs. Using your hk as the audio /visual switcher may resolve this issue-and by the way the hdmi cable has audio built in. I hope this was of some help and thanks for choosing FixYa, good luck Prodzilla.
Apr 20, 2011 | Harman Kardon AVR 130 Receiver
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Left side crackling noise Blown channel?
Would check your balance settings. Make sure your not balanced more to left than right. Next i would try to swap over one of the speakers from right side to left to see if it crackles. If not replace left side speakers.
May 19, 2009 | JVC KS-FX200 Cassette Player
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 02, 2007 | Harman Kardon AVR 325 Receiver
Harman Kardon AVR 130 Receiver Logo
81 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
