Question about Fujitsu Siemens LifeBook N3010 Notebook
Booting problem Whenever i power on the laptop the following message comes up... We apologize for the inconvinience, but Windows did not start succesfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked. If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you aren't sure what caused the problem, choose Start Windows Normally. .... no matter what option i choose, it restarts again and again and the same screen comes up.
  • Fujitsu Siemens Master
  • 13,433 Answers
Your going to need the windows cd, you can try fixing the problem by entering the repair console, by pressing R when asked to on the first windows setup screen.
When your in the console type chkdsk and press enter, this should scan your harddrive for problems. you might need to use the force scan option if the disk is marked clean.
after its done shutdown your computer and try starting windows again, if it fails your going to need todo a repair installation, proseed back to the windows setup, install windows and when asked try to repair a old windows installation if that doesnt work.
try eraseing the old disk partitions in the setup and create a new one and install windows on it.
If that goes well, your going to need to get your laptops drivers. witch can be found in your laptops website.
If you need more asistance, let me know. Good luck.
Posted on Mar 18, 2008
  • Ekse Mar 18, 2008
    if you dont have a xp cd try to borrow one. your fujitsu might have a system restore disk.
    Sergeant:
    Champion:
  • 277 Answers
Reinstall your windows...
2 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: My computer won't boot.
This would be a good time to recover or roll back what you did, There must have been a change in your configeration.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 09, 2009
My emachine computer doesn't start up
Start in Safe Mode then reboot. Windows 95 & 98 used to this all the time.
Oct 06, 2012 | E-Machines eMachines Desktop PC
I had to reboot my Eee PC; however, now a message comes up statting the following: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might...
If you added any exta hardware means kindly remove it and boot the computer
Then you try boot by selecting the option of Boot using last known good configuration.
If the boot is successful then you can boot later booting without any problem.
If boot is not successful and this problem is happened after installing any software or driver software means boot in safe mode by pressing f8 key and uninstall it
Mar 12, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Laptop start up problem
Have you tried performaing a recovery ?
Feb 15, 2010 | Toshiba Satellite Pro M10 Notebook
I have a benq joybook 5100 and xp home edition.I formatted my notebook.I want reinstall from Home edition CD.But windows 98 starting... " 98 start file comes and "quick restore" a window comes."english" to...
you can use either two system. just follow  the screen when installing it... put it on the other partition (drive)....
when starting you can select xp or 98.....
Jan 28, 2010 | BenQ Joybook 5100 Notebook
Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Jul 31, 2009 | Samsung NC10-14GW Notebook
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Windows laptop won't boot -
Try pressing the F8 key at start up. This should take you to safe mode, from here you will be able to shut Windows down properly and reboot without the loss on any data except for what you were working on at the time of the power loss. If it won't let you do this and stays in the same loop, it could be that the hard drive crashed and needs replacing. I don't do data recovery from a dead hard drives, so I can't give you an estimate on that, but a hard drive replacement, system reload with drivers and updates will run anywhere from $150 up to $600 depending on what you want.
Jul 01, 2008 | Gateway MX6920 Notebook
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
Unable to get PC to boot
Does it have a floppy drive? if so, check if there is a floppy disk in the drive.
Let me know, and we can go to the next step.
Jan 10, 2008 | Compaq Evo N610C Notebook
Fujitsu Siemens LifeBook N3010 Notebook Logo
391 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
