Question about ViewSonic VA2012WB Monitor
No Display. Checked all the cords, everything seems OK. However, a "No Display" warning shows whenever I turn on the monitor, and after a second retreats into standby mode. Tried on two different computers. The screen went black suddenly after about 2 hours of use, when I restarted my computer. I have had this monitor for over a year and a half and have never had any problems whatsoever. Thanks.
  • emperor886 Mar 18, 2008
    Hi, nothing for my monitor appears on that site. Any other suggestions?
    Thanks Again.
  • 117 Answers
The problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Posted on Mar 18, 2008
I tried to use my acer as a second monitor and it is connected to my GTX 550 Ti graphics card just like my Benq monitor. Whenever I turn on my computer the acer monitor shows the acer logo and then s
Incorporating a second monitor is a great Idea, I've used three to four on my workstations for many years. Setting up multiple monitors involves more than just hardware, the card manufacturer's software and operating system is involved. Since you didn't note the OS, I'll assume Win7. First, simply right click the desktop, and select "Screen Resolution" to see a page headed "Change the appearance of your displays," below which show be a graphic that shows both monitors with a number "1" and "2" on each. Arrange them by dragging and dropping them to reflect your physical arrangement. Then, select the fourth drop-down titled "Multiple" Displays" and select "Extend desktop onto this display," then click the "Apply" button followed by the "OK." button. If your hardware and drivers are set up properly, you should have everything working at this point. Your Nvidia software should have installed a control panel item that you can use to make tweaks to your system. You can also contact Nvidia technical support for more detailed, OS-specific assistance.
Jan 17, 2015 | Acer 23" LCD Widescreen Monitor S230HL BD
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
All the components are working properly but i am not getting anyh display on my monitor i replaced every thing and checked my monitor is working ram is working cpu fan is working power supply is ok smps is...
1- evolve the battery.
2- install it again but upside down.
3- turn on the PC.
4- wait 15 seconds.
5- turn the PC off.
6- install the battery correctly and enjoy. please rate.
Jan 17, 2011 | Mercury P4VM800M7 Motherboard
Monitor say clear paper jam then press ok. It indicates that the problem is at the back of the printer (the protruding compartment) but I have taken this off examined everything and there is definitely no...
The clicking could be because it thinks there is a problem. Try doing the procedure for resetting the memory on the printer...
(For step 4, do # 3, # 6 as well)
  1. With the unit turned on, Press the Power button and turn off the HP All-in-One.
  2. Unplug the power cord from the Wall Outlet and then from the Unit.
  3. Wait for 20 seconds , Plug the power cord into the wall outlet.
  4. Press and hold # and 9 while plugging the power cord back into the unit. Continue holding the buttons down until the display goes blank or it shows a message.
  5. If the printer does not turn on automatically, then turn on the unit by pressing the Power button & follow the instructions that display on the HP All-in-One to select the settings
Aug 31, 2009 | HP Officejet Pro L7680 All-In-One Printer
Computer keeps turning on and off, plus monitor won't display
Sounds like a loose wire inside the system touching something inside and shorting it out. My brother had this same problem. I brought it to my house to work on it and it was fine, no problems. Open the panel and look for any wires that are touching metal or something else and tie it up out of the way. I won't swear that is your issue, but sure sounds like it.
Jul 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
No display showing
How did you check the graphics?
Laptop or desktop?
Have you got access to another monitor you can try?
This could be a bad monitor' Any post screens at all?
Oct 18, 2007 | ASUS AX800 XT/TVD 256 MB (GDDR3) Graphic...
Monitor will not turn on
1 check plug & socket 2 check for cord 3 power supply in monitor to br checked 4 if it is ok check for horizontal section. if you are not tech person get the help. good luck
Sep 28, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Open Questions:
ViewSonic VA2012WB Monitor Logo
204 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
