Question about Samsung HLP4663W 46" Rear Projection HDTV
BP9600674A color off after changing color wheel
  • 2 more comments
  • timbo777 Mar 18, 2008
    Just changed color wheel on my Samsung and now my squealing sound is gone but my picture is all blue.
    Anyone have any input?
  • Mark Perrotte
    Mark Perrotte Mar 31, 2008
    I have a HLP-6163W with the exact same problem. My picture is high def quality, but the colors are all off.
  • Anonymous Dec 06, 2008
    What and where is a DMD board? More info please. Bowl games coming! DJ
  • Anonymous Dec 12, 2008
    Thank you all...wife was getting on my nerves because I decided to fix it myself and did not know what the problem was. God bless the Internet.
The jumper that you need to remove is a small usually black block of plastic approx 1/4" in across and 1/8" thick located near the center of the shiny silver colored apparatus into which the color wheel is plugged. Mine had a label that read FDB Bearing Color Wheel, BP67-00099A and two illustrations indicating open and shorted conditions. The label was just over the jumper. I pulled it out with needle nose pliers and the problem was solved. GndLoop
Posted on Dec 06, 2008
The new color wheel has a different bearing, there is a mod you have to perform, it includes removing a jumper. There is a jumper
near cn810, you pull it , that corrects most of the problem, the color then needs to be touched up. With the set off, you press mute-1-8-2-power, select ddp1001, then index delay, adjust the bar is a uniform red color.
Posted on Aug 13, 2008
  • 59 Answers
This could be a couple of things. First I would take out your color wheel and put it back in, it may not be seated correctly. If you still have a blue picture, there is a jumper in your DMD board. You must have the correct color wheel to match you DMD board. Turn your TV off and take out the jumper.
Posted on Mar 22, 2008
2 Suggested Answers
SOURCE:
SOURCE: i own a dlp model hlp5063wx/xaa. the color wheel
the new wheel is an air bearing type. you need to remove the jumper from cn810 on the dmd board. this will fix your color problems.
Posted on Dec 18, 2009
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv Tech.to change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
High frequency noise
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
Sep 11, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
May 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
No color
This tv have a colors wheels it dead,it spinning off of it axis.That why u getting black&white picture.Hire a tv tech. to change the colors wheel.Because it hard to change the colors wheel,u never done it before.Have to take out alots machanicals parts before even can get to the colors wheel to change it.
May 14, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
1,757 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
