AKAI CASSETTE DECK IDLER?
AMAZING CLICKING NOISE WHEN IN PLAY, REWIND & FAST FORWARD-AKAI GX F90
    Master:
  • 518 Answers
I wonder if it has a counter and if so, is the belt that drives the counter too loose? Is the counter working?
Geno
Posted on Mar 18, 2008
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
The tape cassette doesnt rewind
This can be a toughy without having the unit but the Chinese decks (After 1992 vintage) all but the expensive units and here are the makes they are using the same mechanism. This deck has two belts and the one is from the motor to the capstan and the other is fed from the capstan (under the flywheel) to the fast forward and rewind mechanism. If the fast forward is okay and the tape plays okay then the belts sre working and the rewind gear is out of position and if you are lucky then all you do is to push the left reel spindle in and replace the small plastics circlip which by the way do come loose sometimes. If that does not help then is it sometimes cheaper to buy a cheap portable set and fit that into your deck The motor on some is on the side and others sort of on top depending if it is a top loading or front loading machineI have seen these same mechanism in the following makes Philips Telefunken Akai Sony Teac Supersonic Roadstar and so on I hope this help.
Oct 08, 2014 | Audio Players & Recorders
Play button and fast forward will not stay down,click down momentarily but then click off again--- fast rewind works perfectly
No Idea- you need to state a model and brand to get an answer. Could be broken keys if it is a piano type button cassette deck.
Jan 21, 2014 | Audio Players & Recorders
The PLAY function of my Cassette desk doesn't work anymore
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Aug 10, 2012 | Kenwood Audio Players & Recorders
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Feb 13, 2008 | Teac R-H500 Dual Cassette Deck
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
367 people viewed this question
 Grubhead
Grubhead
