Question about Hotpoint HSS25GFP Side by Side Refrigerator
Refrigerator not cooling
The freezer and refrigerator are not cool. I'll have to fix it myself. Can you help me? I cleaned under and behind the unit and also defrosted it. I hope you can help. Thanks so much!!
Wendii
  • Anonymous May 02, 2008
    I have an Electrolux larder fridge and although the light comes on it doesn't get cold. How can I remove the stat and replace it.
    Thanks very much, David.
I have a HSS25GFP side by side Refigertor. The Refigerator side done not want to get cool i dont know why I tryed turning it off for 24 hour and it still at 60 degees. please HELP. Cris
Posted on May 09, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Not sure of this model, but if its a manual thermostat does it click when turned and this is always the first place I start if it is not a fan assited unit, putting your hand on the compressor ( black pot at rear / bottom usually) and turning stat to maximum cooling to see if compressor fires up is a good starting point. if fan assisted check the evaporator and see if its frozen, if so then you may well have a fan gone. If the fan is ok and its frozen then defrost it, and turn the stat to warmer. if it still freezes then you may have a gas shortage.
If the compressor is running and it freezes the back plate in only one place and not across the whole unit then I would suggest that the gas is short or if running on 143a gas you may find that the evaporator is actually blocked and am afraid that the only cure for that is a replacement evaporator and re-gas.
I would plump for the thermostat from experience though, make sure you label where each wire comes off of it so you can fit it back correctly.
Posted on Mar 18, 2008
Moaning noise from freezer and chronic ice puddle on freezer floor. what could if be and how to fix myself.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 12, 2011 | Refrigerators
I have a 19 cu.ft. refrigerator. Freezer seems fine but fridge is intermittently functioning. Can I fix this myself or I need help from specialist?
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Admiral Refrigerators
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
My freezer is getting a lot of ice buildup at the bottom and I am now getting water buildup under the storage bins in the refridgerator as well. What is the problem and can I fix it myself? Please advise....
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 25, 2010 | Whirlpool EV171NYMQ
Why is the panel between the freezer and refrigerator hot?
Hi, try vaccumming under your frig coils, and pull away from the wall and clean under there too. I would check to see if the fan behind the unit is spinning(its supposed to cool the compressor) if its not you will need to replace that. A pretty common problem easily fixed
Jul 19, 2010 | Sub-Zero 695/S Side by Side Refrigerator
GE Refrigerator Not Cooling (TFX27ZPBGWW)
The unit isnt defrosting hence the ice on the back panel. Either your bimetal thermostat is open or the heating element is shot. Most GEs they come together so happy hunting. Those parts are behind the frosting panel
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer not cooling enough
Jimmy,
Check the condenser coil and clean it if it is dirty. It is located under the machine behind the grill in the front, or in the back of the machine near the compressor depending on the make and model. Also make sure that the condenser cooling fan near the compressor is working. If the refrigerant is not cooled properly in the condenser the system will run hot and not cool properly inside the freezer.
If this does not help your problem, you will probably need a refrigerant technician to check the system. A rule of thumb for refrigerator repair, Freezer working but Fridge warm = airflow blocked inside the unit somewhere, Fridge cooling but Freezer too warm = refrigerant problem. This is usually a major problem that will cost too much to repair than is cost effective . Check your owners manual for warranty information. Look for coverage for the "sealed system". This is usually 5 yrs but can go much longer depending on make and model.
Let me know what you find out. Please post the model and serial numbers if you have any more questions and I will try to help.
Thanks, Mike
May 10, 2008 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
160 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
