Question about Nikon F80 35mm SLR Camera
ERR sign keeps blinking in the lcd
My cam didnt rewind fully. now it doesnt reload film. ERR sign keeps flashing. hope you can help me.
  • Anonymous Jun 14, 2008
    The err sign keeps blinking but fixed its self once now it is just stuck noyhing works on the camera
  • Anonymous May 11, 2010
    I hope you have been able to reslove your problem by now. If not I'd like to ask a few questions so you can save your memories on film. Does this just happen when you are loading film or does it also happen when you are taking a picture? Was you last set of film completly secure in the tube when you opened your camera? Have you been in any strange weather conditions with it? Have you left it in the car then gone inside and had the message? Is it freezing up on you at all, does it make you waste film to advance to the next frame? "e" is many things with Nikon. It just lets you know that there's an error. I know these are alot of questions but there are so many variables with cameras because they are metal, glass & plastic.
    Scholar:
  • 170 Answers
First check the batteries. Are they fully charged? If you still have the same problem, try this:
Is the film (that which did not rewind fully) still in the camera? If so, open the film chamber door once in a dark room and close it again. Try to rewind the film again. This could possibly be the result of the film getting stuck somewhere, preventing the camera from rewinding it.
Posted on Feb 06, 2009
SOURCE:
I bought new batteries for my N65 and my camera keeps blinking ERR.
The manual mentions only 2 conditions where the Err message appears. First if it is Err + E at the same time, the film has not completely wound and needs to be reloaded.
If it is Err alone, the manual states to fire the shutter and see if the message remains. If it does, to contact a Nikon Authorized Service Rep.
Jun 23, 2011 | Nikon N65 35mm SLR Camera
I have the same problem. An N70 with the err message. If the rewind buttons are pressed (without any film in the camera) the camera tries to rewind but will only stop if the back is opened. I tried...
The Err message alone indicates that a malfunction has been detected, and the manual recommends to fire the shutter and check for the message to clear. If it does not, to contact a Nikon Service Rep.
If it is Err + E, the film did not advance properly and needs to be reloaded.
May 03, 2011 | Nikon N70 35mm SLR Camera
My Nikon N75 says error and there is a flashing circle with a dot in the middle when i look through the lens.... What does this mean?!
If the LCD panel shows "E" then the film isn't loaded properly. If the LCD panel shows "ERR" and "E" blinking, then the film is not correctly advanced. If the LCD panel shows a blinking "E" when the exposure meter is turned on, then film remains in the camera after it has been rewound. In all cases, reload film.
If it's not one of those cases, or if the problem persists, please reply to this post giving further details.
Feb 06, 2011 | Nikon N75 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
My nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Jan 03, 2009 | Nikon N55 35mm Film Camera
Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
Nov 30, 2008 | Nikon N75 35mm SLR Camera
'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
Sep 23, 2008 | Nikon N80 35mm SLR Camera
My camera won't do anything but flash the Err message
Make sure the lens you are using on the camera is set to the minimum aperture setting. i.e. f22,f32 (highest f stop number)
Dec 28, 2007 | Nikon N55 35mm SLR Camera
Nikon F80 35mm SLR Camera Logo
281 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
