Question about Dryers
No heat in old dryer
Where do you get parts for a old Maytag dryer? D-808,
The ignitor works but the gas is not turning on, so I
get no heat.
  • jjet9183 Mar 21, 2008
    Thanks for the info, you gave me what I was looking for.
    Master:
  • 518 Answers
I think you have the Model wrong, maybe it's a DG808? Try looking HERE for a diagram and parts.
Geno
Posted on Mar 18, 2008
I have a Maytag dryer,model# mdg2706aww. Its about 5 years old, was working fine then all of asudden it stopped getting hot completely. Need it fixed but dont have a whole lot of money. What part can it be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Maytag MDG2706A Gas Dryer
My two year old maytag epic z dryer does not heat anymore
heatman101
Jul 05, 2011 | Maytag EPICz Electric Dryer
Maytag dryer mug15pdaww won't light, the ignitor
heatman101
Jun 16, 2011 | Maytag Dryers
Drum runs and does not heat. The dial does not move. It does not shut off. It is a Maytag gas dryer about 12 years old. Has worked great untill this problem.
heatman101
Apr 19, 2011 | Maytag Dryers
My maytag MD-1 dryer will heat at times but latley has not heated, had tech check the heating element and it was okay, it was working okay when he left , but now want heat,what to check? the dryer is 4...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag gas dryer won't heat. I have replaced the gas solenoids, If I tap the gas valve it lights. Old solenoids check out with correct ohms.
heatman101
Nov 11, 2010 | Maytag MDG2600BWW Gas Dryer
My dryer sometimes smells of gas inside the dryer Maytag model mgd6200aww
Hi, The ignitor is not working right...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Maytag MDG6657BW Gas Dryer
Dryer wont get warm... intermittently works... sometimes canhear the ignitor spark, sometimes not. Completely cleaned all of the lint in the machine, exhaust line, etc... and got alot of lint. Thought it...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
No heat in gas dryer..replaced the ignitor..worked..then when he pushed it back into place it quit heating..the ignitor is lighting up but it is now not getting gas...and we have gas in the tank
If the ignitor glows then shuts off but does not lite (it will do this over and over) then the problem is one of the coils on the gas valve is not working. The coil kit is easy to replace the part number is 12001349 and should run about $30.00. They secure to the top of the gas valve just in front of the ignitor you replaced.
If the ignitor continues to glow and does not turn off then the part you need is the sensor part number Y303377 which mounts to the burner box real close to the ignitor and runs about $25.00
I hope this helps.
Apr 23, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Marvin
Marvin
