TV setup New TV unable to setup
  • Anonymous Jun 08, 2008
    just purchase a swisstec lcd from currys with a oneforall urc7711 and can not code tv,can you help
    Genius:
  • 1,027 Answers
Posted on Mar 18, 2008
SOURCE:
I'm having issues on loading Netflix onto my second TV it keeps telling me it's unable to connect to Netflix
Did you connect the television to the home internet system. Is it a new Smart TV? Did you set up the Netflix account on it?
how to setup netflix on second tv Google Search
Mar 10, 2018 | Computers & Internet
Am unable to set up my new Phillips TV
not sure if this will help you out,but if not go to this link...
Press the button on the remote control to access the home menu. Use the cursor buttons to select SETUP and press the 'OK' button to confirm. Select CONNECT TO NETWORK and press the 'OK' button. Check whether your router supports Wi-Fi Protected Setup (WPS).
47PFL7666H/12 Philips 7000 series Smart LED TV 47PFL7666H 119 ...
www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=47PFL7666H/12... set up my new Phillips TV Google Search
Oct 23, 2017 | Computers & Internet
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Can't use remote
Setup code for Olevia TV seems to be :1027
For more details to get codes and setup proceedigns, visit this site Electro-help. Type in 'electronicshelponline.blogspot' into your browsers, search box, and click search. it is an electronic equipments service help site in English language. A blogspot site. Pull up older posts there.
Jun 23, 2012 | Olevia LT32HVM 32 in. LCD Television
Only unable to hear when on net cast, I.e. Netflix. Can hear dvd's without any problems.
Check the cable connections on the back of your TV and whatever unit you use to receive TV service whether it is Direct TV or Cable. Is this a new setup? Your audio cables must be installed wrong. Look through your manual for a set up diagram.
Dec 29, 2010 | LG Televison & Video
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
RCA 20F512T, unable to get sound on tv. It worked
check in menu, enter in the audio setup and check if tv speaker is in on.
Apr 21, 2010 | RCA 20F512T 20" TV
Innovage jumbo tv remote
how do connect the remote to the television??
Sep 11, 2007 | Televison & Video
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Ekse
