Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
LCDTV - Picture problem
The picture on my Sharp Aquos 46"; lcd has a bunch of lines on it. On the HD channels it looks like the picture is behind a screen of lines, on the non-HD channels the lines are colored a thousand times bigger.
Nothing happened, I was watching and the lines just appeared. It is connected from a HDTV/DVR cable box via hdmi and there is a upconverter DVD player connected via component cables.
Help, is the tv a goner, it is less than a year old! thanks.
  • Lainie966 Apr 06, 2008
    My sharp lcd tv is about 14 mons old. This morning when I turned it on the picture looks like it has a screen over it ( like a window screen) I cannot raise the tv volume, only the cable volume.
    Sniper:
  • 53 Answers
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Posted on Mar 18, 2008
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Tirned on our sharp Aquos HD tv this morning and all channels have vertical lines through the picture. Never had this before.
Suspect video processing board or driver board for that section of the panel. Recommend taking it in to local repair facility... To complex to fix at home... Have a great day HDTV GURU JAY
Mar 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Damaged the LCD - Sharp 46 in. LCD Full HD Television, AQUOS®
Yes it is possible to replace the panel. I would suspect that it is cost prohibitive however. I am willing to state that the cost of the panel will be close to if not more than the cost to replace the TV.
Sorry about the bad news.
Dan
Feb 02, 2009 | Mitsubishi VS-5076 50" Rear Projection...
Have tv plugged in on hdmi cable but picture only showing in 480i how do i change to 1080p
You need to verify that you have hd service with your tv provider first. Then, you need to find out which of your channels are being broadcasted in HD because not all of them will be in HD. HD cable and satellite is not capable of broadcasting in true 1080p. Some of them have on demand services that stream 1080p movies, but thats about it. Channels can only go up to 1080i(which is still beautiful hd). Make sure your HDMI cable is version 1.3 and you should be good...good luck 2u
Dec 12, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
52 inch aquos sharp tv
Just bought a 52" Aquos TV 27000/1 newest model for 2008 my husband is putting it up and said the non HD channels don't look real good. Is there anything we can do to improve the picture on the non HD channels?
thanks,
Cathy
Dec 06, 2007 | Sharp Televison & Video
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Dec 06, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
282 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
