Where can I buy paper for the Sharp EL-1611P?
This Uses standard 2 1/4" paper. You can purchase this from any office supply store online or in your area.
Just ask for a roll of standard 2 1/4" paper for calculators.
Hope this helps.
Good luck.
Mac =)
Please remember to post a rating if I have helped you with your question.
I looked up the user guide for your calculator and it says that the rolls of paper is the standard size rolls.
I think you are missing the paper roll holder that is supposed to be on the outside of the printer.
The roll of paper is not supposed to go inside the calculator.
Look at the user manual here in a pdf file:
http://www.sharpusa.com/files/cal_man_el...
If you are missing the paper holder, you can try to make one out of a heavy duty metal coat hanger or some other metal bar that you can bend. (If you are going to use a metal coat hanger, Ive used the vinyl coated hangers that seem to work pretty good.)
I've have done this before for some of my customers.
Look at the manual to get an idea of where the holder goes and what it looks like.
I hope this helps.
Good luck.
Feel free to ask any other questions and also remember to rate my answer if I have helped you.
Thanks.
You can buy EA-7100P paper (1" diameter) for this calculator at
http://www.calculatorsource.com/s-ea7100p.html
OfficeMax
http://www.officemax.com/catalog/sku.jsp?productId=prod2240487&history=u4hy1im0|prodPage~15^freeText~paper+roll^paramValue~true^refine~1^region~1^param~return_skus@yjzscnfq|prodPage~15^paramValue~true^refine~1^region~1^categoryName~Paper^param~return_skus^categoryId~494^return_skus~Y^parentCategoryID~cat_10003
The paper rolls at the office supply store are too large to fit inside the calculator. The width of the paper fits fine, it is the diameter of the roll that is a problem. I need rolls that are only 1" in diameter. Do you know where I can find this type of paper?
