Question about Mitsubishi WT-46807 46" Rear Projection Television
No sound in hd 1080 mode.
I am having problems trying to get sound from the tv speakers when the tv is in 1080 input. for example if i select chanel 773 wich is espn hd. if the tv is in 1080 mode no sound. if it is in 480 mode i get sound. any suggestions other than turning on my stereo and playing it through there.
    Sergeant:
    Champion:
  • 301 Answers
Check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Posted on Mar 29, 2008
I connected my dvd player to my coby hd tv, and the movie still want play, maybe I have it on the wrong chanel. What chanel should the hd tv be on?
Are you using a HDMI cable? Push the SOURCE button & select the corresponding HDMI input with the HDMI input from your DVD player. The HDMI inputs on the tv should be numbered & you can then select the correct number HDMI on the source screen. Good luck.
Sep 02, 2013 | CobyElectronics Coby Electronics Coby...
I'm trying to connect my ps3 to my samsung le32r74bdx but when i connect the cable's either by the scart lead or the hd cable i get no home page from my ps3
yes use hdmi cable or counpounts ? tell ps 3 only 720 p on this samsung max out puyt dont use ps3 in 1080 p mode in video settinsg ok
Oct 15, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
How do u put tv on hd input
If this model has that it will be one of the rear sets of component jacks which will be marked as HD or 1080-----use the input button on the remote or the set if there to change to the correct input on the set. Hookup and select correct input.
Dec 03, 2012 | JVC AV-32S575 32" TV
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
FLM-323B HD blue screen, no signal.
for the remote change battery or get new remote, For the TV make sure that your cable is plugged in properly and not half out. or has it previously been wet. Reason because it sounds like your TV has had a static charge.
Jul 03, 2009 | Polaroid FLM-323B Television
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
HDTV-AT&T UVERSE
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
How to set up hd on this tv
Hi Brien,
You can hook-up your HDTV via the BNC inputs with the right equipment below.
Here is the link to a website that sells video transcoders for projectors and projection televisions. In addition, the link will take you to one particular transcoder that will work for your application.
http://www.curtpalme.com/RTC2200.shtm If you use this transcoder you will have to find a VGA to 5-BNC breakout cable to connect the output of the transcoder to your TV HDTV RGBHV inputs. The extra VGA input on this transcoder will not be used for your application. They sell another product that comes with the cable you need, but I did not see it listed separately. That product is their HDFury Basic Kit at the link below.
http://www.curtpalme.com/HDFury.shtm
Regards,
MyTvGuy
Jan 12, 2008 | Mitsubishi VS-80803 TV
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
