Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-51DX80A I have sound but no picture. I have removed all of the pc boards and touched up any solder cracks that I noticed. When re-installing and powering back up, the tubes glow but it must be just the heaters because they don't actually produce a picture. Any suggestions? Please email me camitchell0@lycos.com
  • Panasonic Master
  • 5,138 Answers
Check your hori out put transistor and next too it is a 1200pf 2k volt cap that goes bad.
Posted on Apr 05, 2008
I have a panasonic pt-53wx54 picture went black with a view vertical color lines then they went and it's now just black. sound is good no picture.. what do i need to do? thanks so much
This is one of several models that had a common problem.
If set comes on with sound and you after a minute or two see a faint odd band of noise top to bottom on the screen to the right side C509 which is a .047 cap at 200 volts is bad.
Cap is seen in attached photo(location marked and cap here gone).
The cap when you locate it from the C509 number which is on top and bottom of board may have a crack or not---it is the cause of this problem.
There is a hard way and a easy way to get at it--let me know and I will explain.
3.00 part....................
Pencil is point to location on Right side board seen from right side.
There are several brown caps here and some plugs here are removed.
I would not try operation of the set in this condition too long.
Apr 20, 2012 | Panasonic PT-53WX54 53" Rear Projection...
I own a Panasonic PT-60LC14 DLP TV. After the tv has been on for awhile, the red color drops from the picture. I have to turn ther tv off and then on again to get it to come back. Has anyone had this...
i used to be a tv technician.it sounds like an intermitent fault,which only does it sometimes.most likely cause is dry joints on circuit board,which is faded or discoloureded solder.try resoldering dry joints ,faded or discoloured solder on circuit board.as its an intermitent problem so it sounds like dry joints on circuit board which is faded solder,which means only half of the current is passing through the circuit..resoldering will allow the full current to go through circuit.
Feb 25, 2012 | Panasonic Televison & Video
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Picture out of line Problem with the Panasonic PT-53WX42 53 in. Rear projection. Possible convergence circuit? How do i change it
Picture colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?Yes.The tv convergence board is dead,the board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board.U must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do soldering work?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit belong to ur tv model and make to repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
Mar 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic TV Shuts off by itself
I had the same problem , Good sign of a cold solder or cracked trace.
On my PT51HX41 after a long check with a magnifying glass I found the problem on the main board just below the AC daughter board there is a Blue rectangular box (relay R801) and it had two cracked solder joints.
Jan 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Look at the main circuit board do you see any burned resistors?
I had this same problem.
Sep 28, 2008 | Panasonic PT-51DX80 51" Rear Projection...
I attempted a repair on my pt-53tw53 by replacing the 110 ic chip ( the one on the diagonal heat sink) but, I think I did a bad job of soldering. When I tested the set when turning the power on the set...
You can repair any of the traces with small wires from the affected pin to the next componnent on that trace. To remove the board label all wires that you disconnect. There are "bridge" connectors that connect the signal bd and main bd. these lift up off the main board and will stay attached to the board youre working on. If you need further info please let me know. Also use solder wick to remove the solder and get a small tip solder iron 30watt from radio shack. The proper way to solder is (1) allow the iron to heat up. (2) touch the hot tip to the pin on one side and then briefly touch the solder to the other side of that pin so the solder flows around the pin. Use the solder sparingly so you dont bridge the pins with solder. (3) always check your work with a magnifying glass to insure the pins arent bridged.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Projection TV
If you are using your TV's internal speakers, then you have a loose connection inside your TV more than likely on your audio output IC. Re solder all connections on your audio output IC's. To locate your IC, trace your speaker wire back to the circuit board.
Feb 23, 2008 | Televison & Video
PANASONIC PT-51DX80A
Normally, the main cause of this problem is the solder connection under the convergence IC's.
You would see rings around the legs that have bad solder joints.
My shop would replace both of the IC's.
I don't have a schematic in front of me, but, I'm pretty sure the IC's are STK392-110. We use the STK392-150 in place of them since they are a heartier IC.
When replacing these IC's, remember to use semiconductor compound on the back side of the IC when placing the parts against the heat sink.
Any questions, respond to this post and I will reply.
Jan 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 51"
First there are a few questions. Did You disconnect fly back xformer (black honeycomb looking deal with red large gauge wires)? Did you make sure your solder splash didn't bleed over on causing shorted amplfier(s)? Have you identified what component has went home to ma ma? You should see discoloration on either board, replace blown fuse power board replace damage part(s) and go over real good before applying power.
Sep 05, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
