Question about Olympus SP-570UZ Digital Camera
I can't download my pictures from my camera to the computer or sd memory card. can you help me?
Alot of cameras have USB cords to transfer pictures to your computer. If yours doesn't (or didn't come with one) you can take out the memory card and put it in your computer. If your computer doesn't have a memory stick slot, take it to a computer store and ask them for a addapter.
Hope this helps. :-)
Posted on Oct 22, 2008
SOURCE:
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
I don't know what happened but my pictures are gone and I don't know how to get them back! Please help!!?!
Assuming you didn't download the pictures to your computer ... and as part of the download option, you elected to erase/remove the pictures (after downloading them) from the camera ... and you have not done anything (on the camera menu) to "refresh" or erase the pictures, or reformat the storage media (memory card) ...
then ...
... if the pictures are stored in a memory card .... you can take that memory card out of the camera, insert it into your computer ( ... or use a card reader, inserted into a USB port) ... and see if you can recover the "deleted" data from the memory card ...
... if the camera only has "internal" memory ... connect the camera to your computer ... and when it shows up as a storage media, try to recover the "deleted" data from the memory card ...
You can (find on the Internet) and install and use various (free) software (on your computer) to recover "deleted" files on storage media (memory card, etc.), ... on a Windows PC ... like PhotoRec, PC Inspector File Recovery, Undelete Plus (or Undelete 360), Glary Undelete, Wise Data Recovery, Recuva Free.
Apr 03, 2014 | Cameras
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
When trying to playback photos from SD Card, the message "cannot playback image" is displayed. Happens when using more than one SD card, which rules out that it is the SC card that isn't working.
which rules out that it is the SC card that isn\'t working Not necessarily, switching SD memory card from one camera to another without formatting isn't going to happen. If the SD card was new and not formatted in the camera that it's going to be used in then there could be a lot of different errors occurring. Also if pictures were downloaded from the memory card to the computer and the card not formatted this will cause a problem as well. If you have been deleting the pictures files then again this could be a problem the card needs to be formatted. Another IF is if you downloaded pictures from the computer to the SD card and then put it back in the camera without formatting then it's not going to acknowledge the card. If you formatted the SD card in the computer then it's not going to work or work properly in the camera. Picture files can go from the camera to the computer but not back again because the computer operating system and software is not compatible with the camera firmware. It all comes back to format the memory card in the camera you are using it in before taking pictures.
Feb 08, 2011 | Canon EOS 550D Rebel T2i Digital Camera
My new t21 display said "unable to access card" my
If you are using the camera to download pictures to the computer you should be able to set around this problem by purchasing a card reader. These plug into the USB port and the camera SD card plugs into the reader, the computer then loos at the SD card as an external Hard Drive. Create a new folder in ? "My Documents" transfer the files from the camera memory card (copy past) into the new folder and you have your pictures not on the computer hard drive.
Do a "safely remove" "eject" or what ever language you computer uses to shut off the connection and disconnect the memory card from the reader.
Format the memory card in the camera always format the memory card after downloading pictures to the computer and always make sure it has completed the download and you have turned off the feed.
Failing this your do two things corrupt the card and possibly the camera software.
Okay another thing that the SD card have is a lock I'm giving you a diagram to see and make sure the card is in the write position.
Diagram
You should be good to go
Jan 20, 2011 | Canon EOS Rebel XSi Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
How do i get the pictures from my camera to the memory card
the question I ask is why would you want to do this?
The camera has XX Mb of memory in case the card becomes full. Generally one downloads the pics on to a PC and deletes the Camera files to start again
If you want to keep the pic files in memory and save them tpo your pc. remove the card for safety.. Interrogate your camera via the connection cord and the software it came with. Download the folder with the pics in memory to your PC. Then delete the files on the camera. Insert the SD card and In menu, set up to save files to SD card rather than memory while there is space.
Please rate my help++++Thanks fore using FIXYA
Apr 16, 2010 | Samsung L200 Digital Camera
Memory card sd
Appreciate the direct "Ask Me".
It would seem that you would have to do it all over again, that is download the pictures again to the SD memory card. But before doing this, you would need to format the SD card using the digicam rather than the PC.
In some cases, it maybe that the picture files (downloaded from the computer) does not match the image property requirements of the digicam so that even if the image files are stored in the SD memory card, the camera is unable to list/view them
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Cant download pictures usb
Take your sd memory card out of your camera, and put it in your computer. A file with your pictures should appear. Copy thoes pictures into a different fold on you computer. Take you sd memory card out of your computer and plug it back into your camera. Your pictures will be both on your camera and on your computer.
I hope this solution helps. Please rate this solution.
Oct 10, 2008 | Nikon COOLPIX L18 Digital Camera
Olympus SP-570UZ Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
