Question about Dryers
Opening a GE electric dryer
I'm trying to open a GE model dde7207sblww electric dryer.
    President:
  • Dryers Master
  • 2,651 Answers
There are 2 screws directly under the main top. open the door and look up 2 phillips screws, this will release the top and from there 2 screws on inside lip of front panel will allow front to came off
Posted on Mar 18, 2008
SOURCE:
GE DRYER STARTS BUT WONT STAY ON
how long does it run for?if it doesn't start right up again and it has to sit for a while before it will start again most likely you have a bad motor.the overload on the motor pops from the motor overheating and resets when it cools down.you need to send more info and the model number off of the machine,open the door and look around the opening on the frame where you put the clothes in,and a better description on what's happening with it.
Dec 21, 2011 | GE DBXR463EBWW Electric Dryer
Dryer eating clothes, getting stuck top right hnd side of door opening
This is an older model but yours has the SAME SETUP JUST NEWER
Most of your newer models have to have the top removed and then the controls and then the front comes off and basically it works the same way as this older one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 26, 2011 | GE DCVH515EFWW Electric Dryer
How to open the cabinet of a ge dryer model dbsr453eb2ww
Open the door the the tumbler. in the front top ledge of the opening you will see 2 screws. Remove those and you should then be able to remove the top
Mar 19, 2010 | GE DBSR453EBWW Electric Dryer
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
It takes 3 hours to dry a load of laundry
if this a 110 volt model, that is probably how long it takes. If this is a 220 volt model, you are not getting air flow. a plugged lint filter. a dryer sheet stuck to the back of the inside of the drum. your vent pipe going outside is plugged or the dryer vent cap outside is not opening and closing normally due to an obstruction.
Oct 10, 2009 | GE Spacemaker DSKS433EB Electric Dryer
Replacing felt around drum - model dpsr610eg0wt
On the DPSR610EGWT if you open the dryer door and look at the top of that opening There are two small phillips screws that hold down the top of the dryer. Unscrew those, lift the top and then slide it to the left to remove the top. Next, near the top of the seams between the front and side panels is a screw. Unscrew the small screw and the front will lift off. Be careful because the drum is supported by the front and there are also wires connected on the left. Hope this helps!
Aug 23, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge dryer
Jim; without the model number it is hard to give specific advise. (model number is usually on the frame just inside the door) To open top, try pushing a putty knife in the seam between the dryer front and the dryer top, a few inches in from each side.
Nov 06, 2008 | GE DBSR453EBWW Electric Dryer
GE 5 Cycle Automatic Dryer Model DDE7207SBLWW
hi peggins,
sorry we were not able to continue, if you have any more question, please use the ask me button.
drcool,
Sep 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
