32" Polaroid TV/DVD combo
The picture goes to lines and there is a very loud staticy noise. When it does this neither the remote nor the buttons work and you have to unplug it. This happened within 4 days of buying it. It happend again a few days ago and today it happened 6 times within an hour and once it turned itself on.
The DVD does not work right either. Sometimes the remote will not operate it and sometimes when it does work, the dvd does not play all of the previews.
    Genius:
  • 1,153 Answers
If it's still new or less than a year take it back or call Manufacturers
Posted on Mar 18, 2008
SOURCE:
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Tip
Polaroid TV DVD Combo Remote Codes Can't find a code to program your universal...
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 | Televison & Video
Tip
Polaroid DVD Combo Remote Codes Can't find a code to program your universal...
I hope that helps.
on May 01, 2010 | Televison & Video
I have a Polaroid 32" LCD TV/DVD combo -
is very simple u have active the close caption mode on ur remote control , this happen sometimes , on ur remote control look for a botton that it said cc or caption or cc mode press this botton till it said on the screen on ur tv cc off or u would see c1 , c2 but u whanto have the one that it said off and that would fix this black box on ur screen
Dec 31, 2010 | Polaroid Televison & Video
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Can't get universal remote to work for polaroid tv/dvd combo
read here
http://www.fixya.com/support/t225581-code_polaroid_tv
May 19, 2017 | Polaroid TDA-03211C 32 in. LCD HDTV
Remote code
I NEED OTHER REMOTE CONTROL AT POLAROID TBX-2000AF 20 IN TV/VCR/DVD COMBO. THANK YOU
Mar 22, 2008 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Polarid tv-dvd combo power trouble
TROUBLE WITH REMOT CONTROL. I CANNOT PROGRAM MY DIRECT DISH
Jan 02, 2008 | Polaroid FLM-3225 32 in. LCD Television
Customer Service Assistance
well first that new, wal mart should just replace it no questions asked, but the 8oo number for polariod is 1-866-289-5168 that should be customer service.
Nov 26, 2007 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
