Question about Car Audio & Video
HOW DO i BYPASS PARKING SWITCH?
ACCORDING TO THE INSTALL GUIDE i MUST CONNECT TO THE PARKING BRAKE SYSTEM BUILT INTO THE CAR. hOWEVER, WE ARE INSTALLING IN A fREIGHTLINER SEMI TRUCK. iS THERE AN ALTERNATIVE? bECAUSE WE HAVE AIR BRAKES.nOT pAEKING BRAKES.
  • 1,586 Answers
You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Posted on Oct 08, 2008
Stuck in gear, break lights don't work
i think?
you meant?
My A/T tranny shift lever is stuck in park. right?
and sure, if the brake lamps are dead, that is normal
fix lamps now. or brake switch is bad, or fuse blown.
always check fuses FIRST. always.
or if in great desperation, (can happen)
the operators guide in the glove box told you what to do....
sure lost.
here is your missing guide
http://justgivemethedamnmanual.com/honda/honda-accord-coupe-owners-manuals/
read the page on A/T park lock emergancy bypass.
takes 1min. to do.
Feb 17, 2014 | 1991 Honda Accord
Urgent car problem
if urgent why post to jeep, all that does is delay answers. or none.
fords.
Faulty Brake Pedal Switch
- Brake Pedal Switch harness is open or shorted
- Brake Pedal Switch circuit poor electrical connection this will also set the PARK lock out feature
do you want do driver a car with no brake lamps(look)
if the lamps work the then the switch may have 2 sides
some do. and the 2nd side is bad to the park lock.
i think most newer cars dont have PARK lock bypass feature
read you operators guide , and what to do if it locks, it will say.
the NEW USA laws made the bypass Illegal. 2007? IIRC.?
nice work , scanning first. real nice.
for sure the brake switch is not sending brake held logic true.
see FSM for tests
on some cars this year, the switch must be calibrated after the swap.
the FSM covers that.
or alldata.com
Feb 16, 2014 | 1986 Jeep Comanche
My 98 Accord wont go into park.
wiggle the steering wheel. (read the operators guide, it tells you this fact)
there are 2 functions,
park lock , lockout.
and key lock.
do you have the FSM for your car? yes, then it covers all that.
also the same guide tells you, there is park lockout bypass switch
in the console. ever see that?
it allows you to shift into or out of park when the park lock fails.
for emergency usage.
this bypass assumes the owner read the booklet in glove box
and knows to use his/her brakes, while doing this bypass.
not running over the kids or pets. RTM
be safe !
Nov 08, 2013 | 1998 Honda Accord
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do i bypass the parking brake on my jensen vm8013hd
I just installed the vm8013hd and I simply grounded the pink parking brake wire to the chassis prior to connecting the power to the unit and it works just fine. No bypass box, switch, codes, etc. Good luck
Dec 28, 2009 | Jensen Car Audio & Video
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Feb 11, 2009 | Pioneer AVH-P5000D Car DVD Player
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Jvc KDAVX44 install issue
Try grounding the parking brake wire instead of attaching it. Should bypass brake requirement for video but really should effect powering on
May 10, 2008 | JVC Car Audio & Video
Car Audio & Video Logo
1,286 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
