Question about Mitsubishi HS-U445 VHS VCR
Change Input source in HS U445 manually or with universal remote control
Hi, I have a Mitsubishi VCR model HS U445 but, I do not have the orignal remote control. There is a manual procedure to change the input mode? I want to connect a DVD through the VCR but I canĀ“t change the input source. I bought a universal control, but without INPUT key on it; the other keys works fine (menu, channel, volume, etc) but can't find the INPUT key. Any suggestions????
6ya staff
SOURCE:
techman
Larry Dillon
  • 3130 Answers
SOURCE: manual input selection mitsubishi hs u575
No I'm afraid not, you must have the remote to perform these functions. You can get a original replacement remote from here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=HSU575&brand_pn=MITSUBISHI_HSU575&mode=large&uid=11752605060460 Good Luck
Posted on Mar 30, 2007
Anonymous
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
There is a reset for this problem and it worked for my VCR. This was a last resort without the manuel.
Only someone with electronics experience should do this.
Posted on Nov 26, 2007
Anonymous
SOURCE: Mitsubishi HS-U445
press the display button for 8 seconds.
Posted on Jan 06, 2008
rusbus
  • 7 Answers
SOURCE: where do i find the input select
Usually there's an input select button on a VCR's remote. You just press that, and it should work. It usually does.
Posted on Feb 16, 2009
Anonymous
  • 110 Answers
SOURCE: I AM ENDEAVOURING TO SECURE AN INSTRUCTION MANUAL
have you tried contacting mitsubishi directly either by phone or internet and asking them for manual or operating instructions? if you have tried that then you might check at library i have had some luck with that. good luck to you and thank you
Posted on Mar 04, 2009
Codes for a mitsubishi vcr on a chunghop universal remote control
Depends entirely on the model # of both the remote and the TV. You can probably get that code from either website, but you'll need the model #'s.
Jul 28, 2017 | Mitsubishi Televison & Video
How do I set the clock without the remote?
http://www.ebay.com/itm/HIGH-END-MITSUBISHI-MODEL-HS-U440-VCR-W-REMOTE-NICE-/230751842386?pt=VCRs&hash=item35b9e1b052
Look at link above, you could buy the original remote from e-bay for $25 plus get another vcr. Only two days left so act fast. Universal remotes - try a different one, other than that its going to be difficult. You could also buy another vcr that has its own remote from a thrift shop or craigslist.
Feb 23, 2012 | Mitsubishi HS-U440 VHS VCR
Looking to obtain a HS-U448 manual and remote.
The manual is available from the Mitsubishi Support site: http://support.mitsubishi-tv.com/documents/HS-U448 . The direct link to the manual is http://support.mitsubishi-tv.com/files/oguide/HS-U448.pdf .
The original remote is no longer available. However, remotes.com has a substitute remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HS-U448&uuid=13065385902780 .
A number of universal remotes will probably also work. The codes will be in any remote that still controls a VCR if the remote was programmed after the HS-U448 was released.
I hope this helps.
May 27, 2011 | Mitsubishi HS-U448 VCR
How go on L1 without a remote control ? Thanks you :)
Can't be done without a remote. Most universal remotes won't change the input to L1 or L2. Logitech Harmony One works, though. It's not cheap, unfortunately.
Jul 15, 2009 | Mitsubishi HS-U448 VCR
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
I don't have a remote, how can I change from SP to EP?
I have an inexpensive universal remote that allows me to make the switch.
Oct 07, 2008 | Mitsubishi HS-U580 VHS VCR
Mitsubishi HS-U445
Check batteries in remote- maybe they are weak/dead. Do the buttons on VCR itself do anything? Unplug VCR for a few minutes, perhaps this will clear the condition. Mitsubishi doesn't show your model, but perhaps this one will be close enough: http://www.mitsubishi-tv.com/j/i/18326/HSU449.html?cid=42
Sep 13, 2007 | Mitsubishi HS-U446 VCR
Input selection
Many of the late VCRs have very limited funtion from the VCR buttons. Power, eject, play, perhaps channel selection, that is about it for most. I assume you don't have the manual? Looked on Mitsubishi website, didn't list a manual for your specific model, perhaps another model would be close enough. http://www.mitsubishi-tv.com/j/i/18344/OwnersGuides.html?tid=5&f1=2005&s=3 Replacement remotes here: http://www.vcrremotecontrols.com/Mfrs/Mitsubishi/MitsubishiVcr.htm
Aug 22, 2007 | Mitsubishi HS-U540 VHS VCR
Can tune mitsubishi HS-651V video player/recorder to watch TV.
Hi Jaco, Have you fed in your Antenna / cable into the Rear of the VCR? And if your VCR has a Input selection switch, just check input to Tuner. You will get Blue screen if input selction is not Tuner but Camera / External source. If this does not solve your problem, then there is no Input selection happening.
Apr 06, 2007 | Mitsubishi HS-U448 VCR
Manual input selection mitsubishi hs u575
Mar 30, 2007 | Mitsubishi HS-U575 VCR
Mitsubishi HS-U445 VHS VCR Logo
298 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
