Question about Video Cameras
Sanyo camcorder no more color
I have approx. 16 year old Sanyo camcorder, it won't record or play in color anymore.
It has recorded about 12 tapes ( 60 min. tapes ) in its life.
I even tried an old tape, I know is color it won't even play in color.
It is Model VMRS2
Any ideas ??
Thanks!!!
  • tvbear Mar 19, 2008
    Hi Dan,
    Makes sense , Thanks for your help!! I will probably just leave
    it is too old to fix. Appreciate your help !( in case others are
    wondering I did try to clean the head, was not dirty and did not help )
    Regards Ted
    Hi Dan, Thanks for the information, it makes sense, as I have already cleaned the head.
    Appreciate it
    Thanks!
    Ted
  • 4,234 Answers
If the head/drum motor is a bit off speed, the first indication will be a loss of color. This can be casued by a bad cap not allowing hte motor to lock speeds correctly. This is not a repair that can be done by a novice. This will be about $150 or so to repair.
Dan
Posted on Mar 18, 2008
SOURCE:
DCR-HC26 will record but will not play
There are two solutions, one, buy a mini dv tape player. They are kind of expensive, but you will be able to get your information off your tapes. Second, buy a used, working mini dv camcorder on ebay and use it to get your information off your tapes. A five year old camcorder is not work fixing.
Jan 27, 2013 | Sony DCR-HC26 Mini DV Digital Camcorder
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
Hi! I have many 8mm and Hi8 camcorder tapes which have my kids' childhood recorded in them. Most of them have not been even played back once or twice. They are in good condition. My handycam doesn't work...
hi,wath i think that is the tape pathern on the camera is different from one to the other, and as
to be adjust and clean the head system,because the traking pulse as to be match for both camera
you will need to see a camera tech because it as to be made with an oscilloscope.
hope that will help you, thats all i can do from here
regrads Alan.
Dec 25, 2010 | Samsung Video Cameras
I have a really old Canovision8, E40, 8mm camcorder that doesn't work anymore. What's the best solution to convert the tapes to DVD or to the computer?
You need Hi-8 camcorder/ Hi-8 player to playback your old Video-8 tapes, hook that camcorder/ player with DVD Recorder, play video-8 tapes and burn DVDs directly.
Dec 27, 2009 | Canon ES400V Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Sony DCR-TRV145E Digital 8 camcorder - won't play or record.
Fortunately they are still making 8mm camcorders usually running less the $200 to replace. It could be more cost effective to get a new model for that price as well. I couldn't record on my Sony 8mm camcorder anymore after five years of use and over 100 tapes that I had recorded. It's plays back but that's about it.
Aug 19, 2008 | Sony DCR-TRV285E Digital-8 Digital...
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
89 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
