Question about Alpine MRD-M501 Car Audio Amplifier
Alpine mrd-m501 amp
Amp powers up but shows the letters " CURR" on digital screen....doesn't pump any sound
  • alpinefan1 Jul 01, 2008
    I have 2 MRD 501's connected to 2 12 inch type R's.
    Banging bass.
    All of a sudden on one of the amps the "current" displays on the amp and no volume. I checked all connections, grounds and cables.
    What next?
The subs cant handle all the power you got it set on turn off all the settings and then turn off your car and remove your face plate and then it should be ok. it does that because the subs cant handle the settings you might just have them a lil high
Posted on Mar 17, 2009
    Sergeant:
  • 300 Answers
Disconnect the speaker wires from the amp, then try it again. If the error message doesn't appear, try connecting the speaker wires back to the amp one by one.
The error message is due to some sort of overcurrent in the amp. If the error does not go away when the speaker wires are disconnected, the issue is most likely with the amp itself and will need professional repair.
Posted on Mar 18, 2008
Display shows food done within 2-3 seconds. cycle is programmed for 15 seconds heating What is causing the problem
That typically means the microwave circuit is not powering on so the oven turns itself off. Most of the time when that happens you will get an error code flashing on the bottom of the screen. If F3 MAG CURR. Look at my previous answers on fixing that
Oct 11, 2015 | TurboChef C3 Single Oven
No power to the air pump
Power board is defective and needs replacing
Jul 07, 2013 | Keurig Special Edition B60 Coffee Maker
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I sent i a question yesterday .Still I'm unable to
If the screen shows running in lower power as an error. I think your powersupply isn't supplying enough power to the computer, and probably needs to be replaced.
May 11, 2011 | Gateway Computers & Internet
My alpine amp displays CURR and nothing coms out!This happened after i was screwing the speaker wire in and I touched the amps chasis and it made a spark. I opened it up I did not see anything wrong with...
According to an Alpine owner's manual, for that type of amp, you should be able to remove power from the amp, then reconnect power to reset the error. If it doesn't reset, either there is another short in the wiring or the amp has permanent damage and needs repair.
Mar 15, 2009 | Alpine Car Audio & Video
Amp displays the letters curr
have you disconnected all inputs and outputs on amp and retried starting it power only? if so your amp has an internal solder bridge and must be repaired by authorized repair center. Repair it or replace it at wholesale price from www.godspeedaudioheaven.com
Jan 31, 2009 | Alpine MRD-M301 Car Audio Amplifier
Alpine MRD-M301
you could have a bad ground or the power wire could have a short i would start there
Jun 25, 2008 | Alpine MRD-M301 Car Audio Amplifier
Negative speaker output touched chasis of amp.
check all fuses on the unit, pull them all.
look for a way of resetting the amp.
LEAVE THE MAIN FUSE OUT TILL THE INSTALL IS COMPLETE!!!
that way you wont short a screw driver across the terminals on to the chasis.
Dec 11, 2007 | Alpine MRD-M301 Car Audio Amplifier
Lights on, nobody home
Appears to be an issue with current. Is the speaker the correct impedance for the amplifier ? Have you confirmed there are no short circuits in the wiring ? I'm not familiar with this particular product,
The alpine catalogue gives recommended amp/speaker combos. If you don't have an aplpine sub, then look at the specs and find a similar one. You may be trying to load the amp too heavily and it will protect itself.
Nov 18, 2007 | Alpine MRD-M300 Car Audio Amplifier
Alpine MRD-M501 Car Audio Amplifier Logo
583 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
