Question about Sony XPlod CD Player w/MP3 Playback CDX-GT40W
Changing faceplate colors.
I've got a Sony car cd player model number CDX-GT40W with seven diferent display color options. The problem is that only the display changes colors; I want the buttons and volume knob color to change too. I havn't opened the faceplate up yet. Any ideas as far as color changing leds, etc would be appreciated...
Only the display changes colors.... your deck is doing what it was designed to do!
Posted on Apr 03, 2008
Buttons of my sony mp3 xplod will not go off when i turn the player off
While the head unit is off press and hold in the volume or source (SRC) button it will bring up a menu with different options go to demo mode and turn it off hopes this helps thanks Jeff J&D services
May 15, 2014 | Sony XPlod CD Player w/MP3 Playback...
Is it possible to use a different faceplate with a diferent model head unit
You can only use the same faceplate.
Some models may will fit but they are different internally.
Nov 08, 2013 | Sony Xplod AM/FM CD Player w/ MP3 Playback...
How do i reset my clock on my sony xplod cdx gt24w car cd player
To set the clock:
Press and hold the select button until the setup display appears.
Press the select button repeatedly until "CLOCK-ADJ" appears
Press SEEK + (the hour indication flashes)
Rotate the control dial to set the hour and minute. (To move between hour and minute, press SEEK + or -)
After setting the minute, press the select button and the setup is complete.
To display the clock, press the DSPL/SCRL button.
Mar 15, 2011 | Sony XPlod CD Player w/MP3 Playback...
How do i change the color from red to green?
This is a link to Sony for your CDXGT510 Owners Manual. Reference page 10 for changing the display illumination color.
http://www.docs.sony.com/release/CDXGT510.pdf
Mar 10, 2010 | Sony CDX-GT510 CD Player
Display doesn't display info....just bright light
Have you tried resetting the unit? Remove faceplate and push the reset button with a ball point pen. If it's a bluetooth model there is a different procedure.
Aug 25, 2017 | Sony CDX-M610 CD Player
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
Aug 10, 2008 | Sony CDX-M610 CD Player
Wiring speakers
For a Sony CDX-CD7000X, the connection would be:
and the wirings would be:
The images were cropped from the unit's spec sheet.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 29, 2007 | Sony CDX-C7000X CD Player
NO SUB OUTPUT
The sub outputs are simply lowpass filtered preamp outputs for use with a subwoofer amplifier. They supply a lowpass filtered signal for a subamp or 'powered subwoofer" like a bazooka tube. Test your "basstube" for 12 volt input power and make sure the "sub" setting on the radio is turned up too.
Aug 26, 2007 | Sony XPlod CD Player w/MP3 Playback...
Faceplate display backlight out
Your display lights are burnt out. This is a common problem. It is covered under warranty. Send it to Sony for service. Anyway, under the Sony faceplate there are two small, different colored leds which control the color. The light is aparently transfered through pieces of clear plastic (best example I can think of is the piece of plastic over the led in a household smoke alram)to most of the buttons and the backlighting. If your display has burnt out you may just be able to swap the leds for new ones. As for the intermittent green could it just be a faulty solder on the board.
Sep 23, 2005 | Sony CDX-CA400 CD Player
Sony XPlod CD Player w/MP3 Playback CDX-GT40W Logo
1,051 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
