Question about Canon DC230 DVD Camcorder
Connecting a canon camcorder DC230 to AN i Mac Problems
The camcorder has no firewire port only a UsB connection.  I cannot link to the i movie feature of the Mac.  It doesn't know the camera is there.
  • Anonymous Mar 31, 2014
    I plugged it in with my USB cord, but Mac OS X 10.9.2 computer isn't finding it in devices. Help! :(
    Guru:
  • 1,894 Answers
Users CANNOT edit their videos without conversion software -- which, according to Canon reps, WILL NOT be provided on the Canon site.
Canon does not provide ANY software for this camcorder -- their reason: the camcorder is ONLY intended for point-shoot-play. Note: Canon didn't even bother addressing the new "VRO" format in the user manual that came in the box or the PDF file on their site (the term itself isn't in their documentation).
Canon totally missed the boat on this one. They could have been packaged a decent camcorder with, at minimum, some conversion software and a better user-guide, thus encouraging their customers to get out there and shoot lots and lots of video for sharing, presentations, and so on
so this using of fire wire is the last option
and this link will tell you the right product that you need.
thank you sir.
good luck
Posted on Mar 26, 2008
  • 3,037 Answers
You can buy a USB to FireWire adapter
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    This website can give you options for purchasing one
  • Benjamin Patri
    Let me know if you have any questions or if you require further help
SOURCE:
Hello! thnx for assisting me! I am having problems connecting my canon zr20 mini dv camcorder with the laptop.I got my camcorder in the usa but I live in europe and im having problems also converting from...
Most laptops use a 4 pin firewire connection as does your Canon.
Get a 4 pin to 4 pin firewire cable to connect. I assuma it's a PC and not a Mac, so use Windows Movie Maker to capture.
All editing applications can be user selected for PAL or NTSC, so stick with NTSC in MMaker.
You cannot convert video standards sucessfully simply by selecting PAL if the source is NTSC. You require specialist software or hardware conversions.
As a side point if you create an NTSC DVD it will play on PAL equipment.
Mar 04, 2011 | Canon ZR20 Mini DV Digital Camcorder
Can I connect a canon 230 to a i-Mac computer G4
does the camera have a usb connector?
As far as I know your imac should have a usb connector to connect the camera to.
Mar 18, 2008 | Canon DC230 DVD Camcorder
My device is connected. Ulead VideoStudio says: Either no video capture driver is install. Where can I find the driver for Sony handycam DCR-TRV30E
  • The USB connection only allows transfer of pictures and movies stored on the Memory stick. The videos recorded to DV tape is NOT accessible through the USB interface. You must transfer taped videos using i.Link.
  • Go get a Firewire (also known as i.Link and IEEE 1394) cable to connect to your computer's Firewire port. Adding a Firewire PC card is relatively inexpensive, but make sure that card has BOTH the 4 pin and 6 pin connections, for most flexibility.
  • Once you connect the camcorder with the Firewire cable, the Ulead VideoStudio will see the camcorder as a video capture device, without additional software or drivers.
Feb 23, 2011 | Sony Video Cameras
My SCD 103 Camcorder does everything BUT will not play back on my LCD screen, Computer or TV (With USB hook-up)....
This camera downloads video over a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software (even Windows Movie Maker will work). No driver needed.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Jan 10, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
Not sure what cord to use to connect my mini dv to my mac.
Depends on the Mac unit you have. If your MAC has a firewire 400 port, then use the firewire cable that came with your camera. Just connect the cable to the camera and the other end to the mac. iMovieHD is already loaded - with the camcorder in "Play" mode, you will "Import" the video.
If your Mac does not have a firewire 400 and just a firewire 800, you need an adapter. Click on this link to see that adapter.
Thank you for using Fixya and your generous rating will be much appreciated.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 20, 2010 | Canon ZR800 Mini DV Digital Camcorder
We would like to import footage from the Panasonic NV-GS 400 digital video camera onto a MAC - is this possible
Yes, you can transfer the videos from the Camcorder to the Mac Computer.
Connect the Camcorder to the Mac Computer using i.LINK/Firewire or USB cable.
I suggest that you use the i.LINK/Firewire cable to connect it to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer.
After connecting the Camcorder to the Mac Computer, open the iMovie Application to capture the Videos from the Camcorder and follow the on-screen instruction to complete the transfer of the videos.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | Panasonic Cameras
Downloading Canon ES8600 Hi8 movie to Macintosh
Just connect the camera to you Mac by using Firewire.
Apr 07, 2009 | Canon ES8600 Camcorder
Canon vixia hv 30 not recognized by computer
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
Nov 16, 2008 | Canon VIXIA HV30 DV Camcorder
Canon DC10 with an Apple Mac
I think you need a firewire connection for video, is there another socket on your camcorder? you can download short mpeg videos to iPhoto via usb
Jul 18, 2008 | Canon DC10 DVD Camcorder
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon DC230 DVD Camcorder Logo
203 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
