Question about GPX D1816 DVD Player
Dark rolling up image
I can hear sound good,but the picture is so dark and keep rolling up(moving up a picture after another)
  • 1 more comment
  • Anonymous May 06, 2008
    rolling picture
  • guest101 May 31, 2008
    It worked fine for a while. I watched several movies, but now the picture rolls. The sound is fine.
  • Mthewheat Aug 05, 2008
    same problem as ckcharliey's
Sounds like you may have inserted the component jacks in the wrong order(ups to nerdherder)
but, could you be trying to run your dvd player through another device?
Posted on Aug 15, 2008
  • 97 Answers
More info (brand/model) might help with specific answer. what type connection your using for video. also how long have you had it. but... my guess is youve got something hooked up wrong. might be a switch to go from Composite (red/green/blue) three cable video to 1 cable rca or s-video or youve got the yellow video cable in one of the composite jacks.
please rate.
Posted on Mar 18, 2008
Dark picture good sound, backgroung image on screem
There may be different reasons for that.
Here's an example:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
Find out the model / chassis and give a better description for the problem in order to get better help.
Aug 21, 2013 | Sanyo 42 in. LCD TV
Picture for about 30 seconds but has sound. TW-5592W82003990
I would first take a look at the screen with set on in a very dark room with a flashlight---do you see a very faint image or picture? That would indicate a back light issue-----Good luck getting a board, I hear the company is again out of business.
Nov 05, 2012 | Westinghouse 32" Flat Screen Lcd Hdtv,...
I can not see my tv picture image
Either the backlight or the inverter board have failed, There could also possibly be a power supply issue. It's not a simple fix and will require a professional to look at it.
Mar 10, 2012 | Toshiba 22CV100U 22 in. LCD HDTV/DVD Combo
My pictures are coming out too dark
There are four ways to make the image lighter
a) more light (flash, sun, etc)
b) slower shutter speed (allows more time for light to "expose" the sensor)
c) larger aperture (bigger hole = more light)
d) higher ISO (basically, amplify the available light more).
If you are using a point and shoot camera, the flash is usually only good for about 10 feet, so trying to get a good bright picture of subjects further away won't work.
Items b, c, and d are handled by the camera in automatic mode. In manual mode, set the iso has high as it can go. Set the aperture as large as it can go, and decrease the shutter speed.
Depending on the camera, you can enable the histogram to see if the images are too dark, usually by pressing the display button while taking pictures. If the histogram is off to the left edge, the picture will be too dark.
In post-processing, (e.g. photoshop), you can use Levels (control-shift-L for auto-levels) and it will move the histogram to the right, making the picture look brighter.
Feb 27, 2011 | Cameras
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Tv very dark what can i do brightness tured up full still very dark
First check this points:
1. How old is your TV.
2. How many times you have change your lamp.
3. Any sort of weird sounds on the back of the TV.
If you are having problems whit the brightness of your TV or you are seeing a dimmer picture, you might have to change your lamp or your ballast, if it comes to a point where you do not see any image at all but you still hear a sound, then its definitely the lamp, if you dont see image or hear any sound, you might have problems with your ballast, also when your ballast begins to run out the picture can get dimmer due to it sending less amount of voltage to the lamp, i suggest to check with a tech to confirm it, or get a second opinion. Hope i could be of assistance.
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
When trying to take pictures this apears on the sceen. !AF
My Fuji E550 manual says this icon indicates the autofocus cannot work effectively under the present conditions. If your image is too dark move to a distance of around 2m (6.6 ft) from the subject. Alternatively use AF lock to take the picture.
My thought -- might try taking the shot even if dark and lightening it extensively in a post production program like Picasa. I never discard a dark shot until I've tried this -- with many good results.
Oct 16, 2009 | Fuji FinePix A303 Digital Camera
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Low or no luminance
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, dark, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 21, 2007 | Philips 9P6040C 60" Rear Projection...
GPX D1816 DVD Player Logo
85 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
