Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 TFT works with laptop, not desktop
I have a Gateway FPD1960 that quit working after 18 months. The blue light,(Power) stays on but no pic. Press the input button and displays: input analog. Then i get a beautiful screen for about 1 sec. I have a GeForce 6100 vid card and am running Win Xp Pro SP2. Tried in safe mode with same results. Hooked the monitor to a Dell laptop with a Ati mobility Radeon x1300 running Win Xp Media Ctr. Works fine. Take back to the desktop with same results as mentioned above. Booted to safe mode on desktop, still no picture. Can press input as above and still get nice screen for 1 sec. Any thoughts greatly appreciated.
  • 4 more comments
  • elbtax Mar 21, 2008
    Thanks, but this didn't help. Got it going for w hours. Unplugged to put on my desk. Same problem. Next day got it going on desktop. Let it sit for 8 hours. Went on the web. Soon as 1st page displayed went back to its old ways......
  • elbtax Mar 30, 2008
    Had some bulging capacitors on the inverter board. Replace 3 - 470uF,25v,105c and 2 - 220uF,25v,105c on the board. Still does the same thing. (Color is more vibrant now.) Next step is to replace all the remaining capacitors after i check for dry spots on the circuit board. By the way: the 470uF capacitors were $1.66 each and the 220uF were $1.00 each at my local electronics store. This monitor was given to me. If i can end up with no more than 30 bucks in it ,and some headaches, i will have gotten a good deal. Thanks for all your help. Will let u know the final results....
  • elbtax Mar 31, 2008
    Don't know about a recall. This monitor i have is only 18 mos old.
    I have now replaced 9 capacitors and the ****** still does the same thing. 1 sec nice screen, then off. I will continue trying diff things. I only have 1 more capacitor to replace. A 100uF, 450v where the power cord plugs in. My electronics store had one but the legs came out opposite ends. Have to come out of the same end to work.....
  • elbtax Apr 02, 2008
    After replacing the capacitors, some needed replacing, checking the two fuses on the inverter board, then pulling my hair out - i did a lot of research on the web and found the solution. (I am using the monitor right now.) I had to re-solder the "dry solder joints at the inductors that power the CCF bulbs. The high heat from the boards being enclosed behind the metal plate had dried out the solder joints.) Ended up being an easy repair. Thanks to all that made suggestions.....
  • Vintak Apr 13, 2008
    My Gateway FPD 1960 monitor goes on for a spilt second then goes black. I can see a quick message that says "input analog" in a blue box. I hooked up my old monitor and everything works fine.
  • m2610_fs Dec 26, 2008
    my screen is blue and reading input analog
    Problem Solver:
  • 19 Answers
Good job elbtax, but did you use low esr capacitors? if not your monitor will not continue to work for long.
The solder joints that you repaired actually do not dry out but crack after many heat/cool cyles. this is a common problem in electronics & expecially cheaply engineered/made products.
Posted on Jan 31, 2012
  • 4 Answers
I got the same problem with this monitor . Except that when I put the moniter on another computer it does the same thing . I just hooked up my old 15 inch tube type moniter to the gateway computer , and it works fine . I figure it has to be the moniter. Any way to find out if there is a recall on these moniters or some sort of addtional warranty from Gateway . Mine is just over 2 years old
Posted on Mar 30, 2008
    President:
  • 778 Answers
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Posted on Mar 18, 2008
  • Frank  Fernandez
    Frank Fernandez Apr 01, 2008
    This is a cut and paste from Gateway's Support Sites Peripherals:
    Limited warranties and service agreements apply; visit gateway.com, or call 1-800-846-2000
    for a free copy. Service agreements are issued and performed by third
    parties. May not be available in all locations. Accidental Damage
    Protection not available in all states. If purchased, on-site service
    technician will be sent if necessary, following phone-based
    troubleshooting. Availability varies. Other conditions apply.
    At the minimum (depending on State and local laws) you have at the minimum a 90 day warranty.
    Considering that you guys aren't alone with this problem on this model monitor, there probably should be a recall and/or a warranty extension.
Gateway FPD1960 monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor will not power on - faint flickering when the power cord is plugged in. Gateway FPD1960 TFT LCD Color Monitor
Hi
i recommend the following
1) if your monitor has a 3 pin kettle type lead, please replace and see if this sorts the issue, if it is hardwired then unfortunatley your monitor is faulty and will need to be replaced/repaired
Please leave feedback/vote if this has been useful
Feb 10, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 900G does not stay on, has power
the_princes, On the rear side of LCD screen that you look at are two each long, straight, cold-cathode-fluorescent-tubes that need to "LIGHT-UP"and provide pure WHITE light to be reflected through the LCD glass panel that you look at from the front side! If you don't have any luck with Gateway providing warranty service or doing a swapout with them, then you should possibly look into having it Refurbished by someone locally in your area. I highly recommend that you go to youtube and watch some video clips of LCD MONITOR REPAIR to see exactly what you are getting involved with. When making a post to tthis site you should always give some "history" along with the trouble "symptom" such as how old is unit and approximate total amount of "ON" time the unit has. I hope you can use the info provided. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Nov 06, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 monitor power suply
Cleaning won't do it.
It probably needs all new capacitors on the board. are any canister looking components bulged up at the tops ? This is the most common problem on the ones I fix.
ebaysbammbammfran
Oct 10, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
399 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
