Maytag washer will not start
8 year old washer will not start. After one load finished I started a second load. The dryer on the same outlet was fine. All functions on the dial will not work, water, sping, etc. My gut tells me it's the dial. Help please. I don't want to spend almost 3 g's on a new red pair of Whirlpools my wife wants.
Thanks,
James
Maytag LAT9356AAE
    President:
  • Washing Mach... Master
  • 2,651 Answers
At the very least you should be getting water in as long as power is good open the back panel ( 3 screws along the top of control), look at the connection where the line cord is coming in. very suspicious that totally dead
Posted on Mar 18, 2008
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
Dryer won't start
check to ensure you have voltage at the outlet
the four wire pattern goes like this
black far right
red far right
white in the middle
geen to the chasis
Oct 01, 2009 | Maytag Dryers
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
I have a Maytag LAT9400AAW. I started a (large) load and it filled and started screeching and smoking. I thought the dryer was on fire until I unplugged the dryer and got behind it. I stopped the washer. ...
You have overloaded you machine. The sound you hear is the belt burning of the machine, Please limit the size of the loads and hope you did not do further damage to you machine
Jan 19, 2009 | Washing Machines
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
830 people viewed this question
Top Washing Machines Experts
