I could nt cutting my pc.
After using my system i am trying to shoutdown but its not shouting down why? give some suggestion to resolve this problem.
thanks
v.selva
First, run anti-virus software. Make sure the system is virus free. I use AVAST FREE. register, download , run, schedule a boot scan.
Any new Hardware or software can cause a glitch in the services to be
terminated when you shut down. Worms and Trojans are notorious for
causing a pc to Hang.
Next, you must remember that the Windows
operating system is not a single program, but rather a collection of
individual services. Each of these services must be stopped during shut
down. Therefore, a glitch related to any one of the services may
prolong the shut down process or cause the shut down process to fail
completely.
Many people have claimed that the Nvidia Driver Helper Service (used
with Nvidia video cards) causes extremely slow shut downs. However,
this is one of those cases in which an updated video driver usually
solves the problem. Other people have mentioned that disabling the
terminal services greatly expedites the shut down process. The Terminal
Services are used for remote assistance, remote desktop, and fast user
switching. If you do not use any of these features, then the Terminal
Services can be safely disabled. You can access the services console by
entering the SERVICES.MSC command at the Run prompt.
Another potential cause of slow system shut downs is that Windows
contains an option to erase the system’s virtual memory and system
hibernation cache at shut down. These security features are disabled by
default because they take a long time to complete, and cause the system
shutdown to look like it has frozen. Although these features are
disabled by default, some privacy software will enable it.
To determine whether or not these features are enabled on your PC,
enter the GPEDIT.MSC command at the Run prompt to load the Group Policy
Editor. Now, navigate through the console tree to Computer
Configuration | Windows Settings | Security Settings | Local Policies |
Security Options. At this point, locate the Shutdown: Clear Virtual
Memory Pagefile option in the column to the right and verify that it is
disabled, as shown in Figure C. If this option is enabled, you can
disable it by double clicking on the setting and choosing the Disabled
option.
Jamesangus,
Hold the power button down for 10 seconds or a little more and if that doesn't shut it off? Disconnect the power cord. Either of these methods should only be used as a last resort in the order posted.
Let us know if you have any problems when you start it back up?
