Question about Canon PIXMA iP1800 InkJet Photo Printer
Hey I was able to install my ip 1800 printer, but through the installation process from the cd, it says my computer doesn't detect the printer, not sure what to do
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Is printer connected directly to pc or through network? If a network is the printer wired or wireless?
  • 518 Answers
Try this:
1. Uplug USB cable from printer.
2. In Control Panel > Printers UnInstall all printers then reboot.
3. Install drivers/software for the printer.
4. Plug USB cable back in and the PC should find it now.
Hope that helps...
Posted on Mar 18, 2008
Lexmark Ed260 does not print
OK, if it's timing out that means the printer is not visible to the network. When you used the setup disc, you said it found the same address? What address does it detect? It will mostly likely start with 192.168.x.x. During the setup process does it offer to use DHCP vs a static IP address?
Do you know the IP addresses of the 8 machines on your network? You'll want to make sure the printer doesn't use the same address as that would cause an IP conflict and prevent it from working properly on the network. Preferably you'll want to use an address outside the scope. For example, if your DHCP server is set to give out addresses from then you should make the printer Hope this makes sense.
If that still doesn't get you anywhere, connect the printer directly to a PC via USB and make sure you can print. It's possible it's an issue with the printer, but my guess it's just a network config issue.
Nov 10, 2011 | Lexmark E260dn Laser Printer
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then computer should install the hardware for you printer.
After installed, restart see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Sep 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Lan setting went off after formating my pc
Try restarting your computer several times if the new OS you installed is XP. However, if your new OS is Windows 7, there is still no problem. If you have not yet installed a windows 7 drivers cd,you will need to get the driver cd for windows 7, and I'm sure there are other things you've not noticed. Otherwise, if your drivers have been correctly installed, just restart your system; the lan driver will automatically install on system start up.If it doesn't install, you should get the lan drivers, depending on your product. Finally, I have both HP and DELL drivers, but I don't have a site yet. Hope the above information helped.
Apr 21, 2011 | Computers & Internet
How can i make my HP printer wireless?
Make sure your Computer have wirelesscapabilities in order to connect to the HP wireless printer. This is how to doit. 1. Insert the CD that comes withthe wireless HP printer into any computer that will use the printer. This willallow to setup the initial software and allow you to configure the initialnetwork settings. 2. Choose where to install thesoftware and which components of the software to install. Typical componentsfor HP printers include the network utility and project creation software. Ifyou already have software for project creation, you don't need to install this.You won't need to install either component for other computers in order to usethe printer. 3. Turn on the HP printer whenprompted. Don't connect it to a computer unless directed by the software. Ifthe printer isn't recognized by the software, you may be asked to temporarilyconnect it via a provided USB cable. 4. Choose a printer name and an IPaddress. The IP address can be dynamic or you can create a static IP address.For larger networks, dedicate a static IP address or allow the HP software tochoose a static IP for you to prevent conflicts on your network. 5. Press "Continue" tocomplete the wireless HP printer installation. The entire process can take upto 30 minutes if you install all software components. 6. Install the printer on othercomputers by going to "Start -- Printers and Faxes -- Add a Printer."Choose "A Network Printer" to view a list of network printers. Choosethe printer name from Step 4 to install and access the wireless printer.
Jan 10, 2011 | Office Equipment & Supplies
Install canon IP 1800
first of all you should install canon ip 1800 software then you should attach canon ip 1800
If you do not have its software then you have to go select your region choose your product and click on downloads to download its driver and install and attach device.
Aug 13, 2009 | Office Equipment & Supplies
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How can i install the canon pixma ip 1800 without disk?
Go to this web page:
IP1800 Support
If the "Drivers & Downloads" tab is not selected, select it.
Enter your operating system in the drop-down menu.
Drivers and additional software links will be displayed. Click on the file name to download them.
Save the file to your computer. (Desktop is easiest if you are not familiar with placing the files in a folder.)
You can then install the driver/software from your computer.
Thanks for using Fixya.
May 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon IP 1800 printer setup
I can't find the install for my printer. Could you help me?
Apr 05, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
27 people viewed this question
old marine
old marine
