Question about George Foreman GRP99 Indoor Grill
GRP99 When the unit gets plugged in dash lines appear and when power is pressed you get 300 degrees and are able to run up to 425 degrees and the timer and temperature light are lite but the unit does not heat up and the temperature display flashes. Also the minute display is on 5 and it can be run up or down.
  • Anonymous Sep 21, 2008
    Had the grill about a year, now everything looks normal and the timer runs down but no heat.
  • 4 Answers
Everything you described is normal, except not heating up.
When you first plug it in, you will see 'dashes' that tell you it is getting power.
When you press the Power Button, the grill will start at the Default Temp of 300F and the Timer starts at 5 minutes. You now change the temp to what you want.
It takes 5 minutes to get your grill to your tempreature, so the timer should 'count-down' as the grill heats up.
As for not heating up, I think you will need to get that 'looked at' for repairs.
Posted on Aug 13, 2008
Whirlpool oven will only get to 250 degrees, help
250' Centigrade is full power, Gas Mark 9, 482' Fahrenheit
This is an approximate conversion chart between gas mark and electric ovens. This information was copied from the rec.food.cooking FAQ.
Gas Mark Fahrenheit Celsius Description 1/4 225 110 Very cool/very slow 1/2 250 130 --- 1 275 140 cool 2 300 150 --- 3 325 170 very moderate 4 350 180 moderate 5 375 190 --- 6 400 200 moderately hot 7 425 220 hot 8 450 230 --- 9 475 240 very hot
Sep 24, 2015 | Whirlpool Ovens
1990 gmc K1500 5.7L, temp. gauge not working:
To review, you have two temp sensors, one for the gauge on the dash and one for the computer. If you unplug the sensor for the computer the reading will be minus 30 degrees or over 300 which will make it very hard to start. Unplugging the sensor for the gauge would have no effect on the computer.
According to the wiring diagram, the wire for the temp gauge is green, and the wires for the temp sensor for the computer are yellow and black.
Aug 24, 2012 | 1990 GMC Sierra
Where is the reset botton on a samsung rfg297 refrig fridg is totally out
There isn't one. If you had a brief power loss unplug it for 20 minutes and then plug it back in. It should restart. If this does not work.. Press the power cool and power freeze buttons for 8 seconds and then press the UP arrow to cycle through the menu. There will be horizontal and vertical dashes in the display if there are errors. NOTE the position of ANY dashes as they appear as there are actually 13 failure indicators via those various dashes. After the last menu the unit should restart. If it does not start after the menu wait 10 minutes to see if it restarts on it's own.
If you note dashes in the temp windows I need to know what window and what positon of the digital 8 indicator it was in. (upper, center, "top or bottom right and left sides" Top or bottom lines i.e exact digit as it would appear in a digital 8 display.
There are also things like the PTC relay, run capacitor or thermal overload that can cause this.
If you have no display at all.... your most likely looking at a control panel failure.
Thanks for choosing FixYa,
Kelly
Jul 05, 2011 | Refrigerators
I get the wrong answers when i'm trying to calculate sinus tasks. ex: sin 41 = -.9165215479 and the right answer is: 0.66 why?
I have no idea where you got that particular value of a sin (41).
At first I thought you might have been using the radian as angle unit, but that is not the right answer. I tried cos (41 radian) and I got -0.9877392775.
Any way, when you are using angles you must select that appropriate angle unit ( appropriate to your problem, that is).
I suspect you need the angle unit to be set to degrees. If you do you will find that sin (41 degrees)=0.656059029 which is close to the rounded up value you call the "right answer".
To set the angle unit to degrees
  1. Turn calculator ON
  2. If you see no icones, press the [MENU] key.
  3. Use arrows to highlight the RUN icon or press 1.
  4. In RUN screen, press [SHIFT][MODE] to enter the (SetUp)
  5. Press the down arrow 4 times to move highlight to the line Angle.
  6. From the three tabs that appear at the bottom of the screen, select the one labeled Deg ( by pressing the F1 key) and press [ENTER.]
  7. Calculate the sine with the angle unit set to degree and you will get the value you are expecting.
Nov 23, 2010 | Casio FX-9750GPlus Calculator
When finding the inverse tangent of a number, how can i get the answer to appear in degrees?
You must configure the default angle unit to be degree.
In Run screen press the [SHIFT][MENU] to access the (SetUp) screen. Use the down arrow to scroll till you highlight the line Angle. The bottom of screen will then display three tabs at the bottom. Press the [F1] key to select [Degree].
Sep 02, 2010 | Casio FX-9860G Graphic Calculator
I have a George Foreman Grill Model GRP99 Series. When I plug it in the panel does not light up. It appears to be heating. I can not tell how hot it gets because the panel is not lite.
the indicator light doesn't have anything to do with how hot the grille gets,that is preset by an internal thermostat and the light just comes on when that temperature is reached, more than likely the miniature neon bulb that light is burnt out, any appliance repair shop can replace this bulb for you
Jul 30, 2010 | George Foreman GRP99 Indoor Grill
How to turn oven on kelvinator wall
Is there a hand diagram labelling one of the button. Auto/Manual switch?.
Apr 11, 2009 | Fisher and Paykel AeroTech Double OD302...
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
George Foreman GRP99 Indoor Grill Logo
335 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
