Question about Jensen VM9410 Car DVD Player
Explorer dvd player reads no disk or says eject
My grandson may have put a piece of paper or something in the dvd player in my ford explorer. can i repair it myself or is it hard to remove it?
Depends upon your level of expertise. you will probably need a small philips screwdriver. put the screws in a small dish, if need be, take notes of how it goes back together. i have done this type of thing before, just take time and don't strip the screw heads.
Posted on May 11, 2008
SOURCE:
I have just the dvd player, the player keeps ejecting the disc and not playing it
Could be lots of things, but here are a few easy ideas:
1) Is the disc Blu-Ray? A regular DVD player can't read Blu-Rays.
2) I think all DVD players can read CDs, but if the disc you're putting in is a CD, maybe that's the problem.
3) Maybe the disc is dirty. Wet the disc, wash it with dish soap (or hand soap, then rinse it clean and dry it off. You can use a cloth or a paper towel for washing/drying. When washing and drying, make motions across the disc from the inside hole to the edge; don't swirl around the disc.
4) Maybe the disc is not the same region as the player. https://en.wikipedia.org/wiki/DVD_region_code
5) You've got a PAL (European) disc and an NTSC (American/Japanese) player.
Aug 02, 2015 | LG Televison & Video
Adv30 dvd player won't eject
Something broke in dvd player, bring in for service or replacement.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 13, 2014 | Audiovox ADV30 10.2
Cannot eject DVD drive
on the dvd drive below the tray normally on the right hand side there is a little hole get a pin or something to fit the hole and insert it into it while doing this the disk tray should manually open this should allow you to get your disk out :)
Jan 19, 2012 | Gateway Computers & Internet
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
DVD will not eject from movie player.
On some DVD player there is a little pinhole next to the opening or tray in case the disk or tray won't eject. You can unbend a paper clip and insert it into hole and see if it will eject. If not you will need to remove radio and have it serviced.
Your vehicle is not that old, take it to the dealer and see if your radio is still covered under warranty.
Good Luck!
May 27, 2010 | 2008 Chevrolet Uplander
Unit does not recognize DVD-R and is ejected from the player
You may need to try a DVD+R disc. Some of the players/recorders are REALLY picky.
May 17, 2010 | GoVideo Go Video DVD/VCR Combo
Dvd player on LG tv/dvd combo, stuck disk in, can't eject and won't play?
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Dec 31, 2009 | Televison & Video
Curtis DVD player - Stuck in Load Mode so won't open - dvd inside - correctly seated - but may not be compatible. I just burned it & was testing it.) Have tried the paper clip in the tray release...
Do the following
Unplug power cord.
Wait two minutes and plug it back.
Keep repeatedly pressing the eject button while you start the unit, before it starts reading cd inside. Do this a couple of times.
If you cannot eject the disk in this way you will need to take unit apart.
Unit won't start until the disk is inside, as it tries to read the disk , disk is faulty and unit get stuck.
Aug 26, 2008 | Televison & Video
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
LG V8824
the small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Sep 21, 2007 | Sony SLV-D350P DVD Player/VCR
Jensen VM9410 Car DVD Player Logo
69 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
