Question about Panasonic KX-TG5632 Phone
Program phone I would like to program my panasonic KX-TG5632 so that frequently called numbers are in memory and automatically dialed by pushing one or two keys.
Hand set reads "Ringer off [2]" How do I get hand set to ring??
Posted on Jul 06, 2008
Why do I need to push a line to dial out
Since the system can make both intercom calls and external calls it is factory programmed to consider a number dialled to be intercom hence need to pick a line before you can make an external call. However it is also possible to program your phone to automatically access an outside line on lifting your handset in the installation manual
Feb 27, 2014 | Panasonic KX-T7730 Corded Phone
Call forwarding
Assuming your telephone service provider offers the call forwarding service, yes. The procedure varies from company to company, but often you dial *72 from the landline, then the number to which you want the calls forwarded. That phone will then ring, and you must answer the call to confirm. To cancel the call forwarding, dial *73 from the landline.
If this doesn't work, contact your telephone service provider for their instructions regarding call forwarding.
Oct 13, 2013 | Panasonic KX-TG5632 Phone
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
No dial tone - I have to dial using the speaker phone
sounds as if this phone will need to paired with the base again.
May 30, 2009 | Panasonic KX-TG5632 Phone
How is the KX T2325 programmed for frequently
Set toggle to PROGRAM (side button) Hit Location Key
Dial number
Hit MEMORY key (lower right) Set toggle to SET
YOU MUST HAVE BATTERIES INSTALLED
Mar 16, 2009 | Panasonic Lands Phones
How to connect additional unit to base unit special code ?
Hello. Here is how you do register your handset below, and a link to the manual its on page 46. The procedure depends on how many handsets you have. If you only had one handset follow the directions below. If you have more than one handset follow the second set.
On the handset push menu, then dial 0 0
On the base, push and hold down the locator/intercom button until the charge light flashes
Press OK on the handset, and it should automatically register in a few seconds.
On the base, press select until you see the intercom number you wish to register it to. Stop there and push the Call button until the charge light flashes
Push OK on the handset, and it should register
Hope this helps
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Feb 28, 2009 | Panasonic KX-TG5632 Phone
Panasonic phone .kx-TG5632. no dial at base and phone,but 3rd phone o.k.
The line was plugged in wrongly. With your help, I realized that.. It's Fine now.
Sep 17, 2008 | Cell Phones
I need programing instructions for a Panasonic Easa-Phone model KX-T3170
For the onetouch buttons 1)push program untill memory light is on. 2) push desired onetouch button,
dial the phone number. 3) push auto button 4) when done press program button.
Feb 28, 2008 | Panasonic Lands Phones
Panasonic KX-TG5632 Phone Logo
222 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
