Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
S catch thank you for the pic, i'am pulling like crazy, and this thing is not budging. i will keep trying, but i'am afraid i will break it. i really need to get inside there, it probably is clogged in the heater. it sprays water out of the hose attachment, just not out the bottom. thanks, randy
    President:
  • 1,673 Answers
Look between the 2 fingers there at the top, If I remember there is a catch in between them that you push down to release.
Posted on Mar 18, 2008
Can't get the Sebo S-class filtration off to replace it. I bent the wire down, didn't move much. I tried to pull it off but, it didn't budge.
The filtration cone just pulls out. That's why there's a looped piece of plastic on it at the base of it. The spring wire keeps it in place so that the door can be locked back on.
Aug 27, 2015 | Sebo X4 Bagged Upright Vacuum
Reveal mop bottle won't come out easily
There is no locking mechasiam, it should just pull out. If yours is stuck maybe something broke check out this YouTube video. She removes the bottle at 3:42. Rubbermaid Reveal Mop
Oct 04, 2014 | Rubbermaid Reveal Spray Mop Kit,...
How do i install a replacement spring in a tool catch
it isn't obvious from the pics but if I had to guess u need to get both the catch and the spring (if u lost it) b/c the reason the spring came out is that the catch is already broken.
Once u get it, it simply pops into place.
look at this page - may help
http://www.vacpartswarehouse.com/Dyson-Silver-Tool-Catch-DC25-DC33-DC35-DC44-DC56-p/dy-911523-03.htm
Sep 21, 2014 | Dyson DC35 Handheld Vacuum
Loose cable vax power 3
Try 'tightening' the screws first even if just a bit. This can possibly break them loose so you can remove them with the normal counter-clockwise motion.
May 26, 2014 | Vacuums
Trigger on my dc07 does not open cylinder flap,what can i do
Hi Stephen,
This is a pretty uncommon problem and it is not terribly easy to fix. I suspect Dyson became aware of it and changed the mechanism as I have only seen this issue with Dyson DC07. Basically there is a long plastic rod from the trigger to the bottom flap when you pull on it the latch is released and the flap opens. Your plastic rod has most likely broken. The unfortunate thing is you cannot buy that rod you might have to buy the complete radix assembly. It normally happens that the bottom end breaks off when someone holds the base in place and pulls the trigger.
If this is the case then you may be able to super carefully glue the pieces back together. Watch the video I linked below it shows how to get the radix apart. The tricky part for you is that you will then need to insert a coat hanger or some other slim long thing into the centre and manually push the release which is right at the base of the radix in the middle this will release the flap.
From there see if you can find the broken bit and repair the pieces. Super glue wont hold, you will need araldite or some other super strong compound.
Of course if this sounds like too much trouble just buy a new radix.
May 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where the power cord goes through the metal casing, there is a plastic thing that protects the cord. I can't get the power cord to slide through nor can I seem to get that plastic thing to release or...
That plastic thing is the cord retainer. The cord will not pull out or push in until the strain relief is pulled out. A needle nose or channel lock pliers should be used. Squeeze the strain relief as close to the housing as possible and pull it out. You can then slide the cord further into the strain relief and replace it in same fashion.
Sep 12, 2011 | Filter Queen Majestic Canister Vacuum
My machine has suction at the port where the canister fits on the base, but immediately sounds clogged with no (or very little) suction going to wand or floor. All filters cleaned (accesible) and no clogs...
I will list the spots to check this vacuum for clogs. First see the first diagram I uploaded.
  1. First thing is to remove the canister.
  2. Then you will see in the diagram "A." Press that button and pull the hose up and check for blockages. Make sure to check for light through the hose to guarantee no blockages.
  3. Now tilt the vacuum forward and pull out the U Bend Airway and inspect it as well (3rd pic in diagram)
  4. Now squeeze the valve release catches to remove the airway and inspect the valve for blockages. (4th pic in diagram)
  1. The diagram above is the pre motor filter many forget to check.
  2. Press the filter release catch and pull the filter housing out.
  3. Remove the filter.
  4. Wash real good and let dry completely.
  • Now the one thing that tends to go bad on these vacuums is the automatic air flow adjuster. When the vacuum is upright the pathway for suction is automatically on the wand. After some good use the little disk in there snaps and the air flow stays restricted in what ever position the vacuum is in. I have contacted Dyson a few other time and they do not sell this part. It is a factory fix only or I would give you the instructions to do it yourself.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi, I have a Dirt Devil Model # M08100REDC. I desperately need to change the bag, but I don't see an obvious way to do it. I'm afraid to try pulling on the cloth tab thingy that's just below the handle,...
You can pull on the tab to remove the bag, but probably a better way is to gently pull on the rubber ring that attaches the bag to the back of the vacuum body. If you don't yank and ****, it should come off without spilling the dirt. There may also be a paper bag actually catching the dirt inside the cloth bag. If there isn't, I recommend you get a package of those. They come in packs of three, and they're disposable -- instead of emptying them, you toss them and install a new paper bag.
Sep 03, 2010 | Dirt Devil Classic M08100 Bagged Handheld...
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Wand
I just took my DC17 apart to determine the problem (noted above). Basically it seems like there is a 'nub' on the lower part of the extension wand. Actually, there are two on either side, one higher (white, facing the back) than the other (black, facing the front). The lower one (black) acts as a brake for when you yank the wand out - it stops the wand from coming out all the way. The little black nub is hitting the inside ribs of the hose and stopping, impeding the wand from pulling out. What seems to have happened is that the hose has constricted a little too much and the diameter is 'smaller' by just a little and therefore the nub catches. Use the trick I mentioned above to work the hose off, a little at a time. Once you get enough hose, you can stretch the hose and it will then pull out without catching. To keep it from doing it again? I am not sure, but if you were to turn the wand/hose counter-clockwise to loosen the coil inside the hose, this may just open up the inside a little bit. I have done this and it is seeming to work. So every time I use the wand, I will unwind the hose counter-clockwise a little bit and see if this helps....
Jul 18, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
