Question about Onkyo TX-SR304 Receiver
Very low ouput from subwoofer preout
My Velodyne VX-10b is connected to my Onkyo TX-SR304 via the sub preout from the receiver. I barely get any bass signal coming out of it at all.
In order for me to get any bass, i have to set subwoofer to "No" on the receiver and run my front left/right channels through my subwoofer amp, and set the crossover on my subwoofer.
Any reason why my sub preout on my onkyo is barely putting out any sound to my sub? i've gone through all the settings and can't find anything wrong?
  • 2 more comments
  • Anonymous Mar 29, 2008
    I'm having the exact same problem, did you find a fix?
  • Anonymous Apr 16, 2008
    Same problem. I set crossover to 200. Still hosed up. Guess I'll return this as I've read of this problem on the web.
  • Phogg76 Apr 28, 2008
    Onkyo SKW-402 subwoofer connected to sub pe-out on the OnkyoTX-SR304 5.1 Receiver. Subwoofer will go into "standby mode" after a few minutes, even with LFsignal present. Must disconnect and reconnect RCA connector from the amp (sub pre-out) to regain signal. Does not matter what the signal source is, tuner, cd, dvd, video, etc. Crossover on receiver is set at 120hz, sub selection at "yes", subwoofer crossover set at 200hz.
    Very frustrating. Assumed better performance with an Onkyo to Onkyo set-up. Guess I was wrong.
  • stephen jaeger
    stephen jaeger Jan 07, 2014
    I thought I had read that the sub out (pre) is for a powerede sub. That is what I have hooked up and it is working fine.
Onkyo to Onkyo, sub/receiver, problem fixed by inceasing volume on receiver. Seems the sub audio input does not pick up LF's below a certain output level from the receiver. So, guess I have to live with that. I only hope my nieghbor in the apartment below me can too!
Posted on Apr 29, 2008
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Posted on Apr 18, 2008
No subwoofer sound
Odds are that your woofer is blown. That or your outputs failed in the power stage of your sub. Pretty sure your receiver is fine.
Jun 22, 2012 | Onkyo TX-SR304 New
Tip
Download Onkyo TX-SR304 Manual
Download Onkyo TX-SR304 Receiver Users Manual
Have you misplaced your Pioneer Download Onkyo TX-SR304 Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Download Onkyo TX-SR304 Receiver Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR304 Receiver
SUBWOOFER VOLUME PROBLEM
Make sure you have the sub connected to the proper output on the receiver and no connections are damaged.
Then check the gain/level control for the sub. on the receiver...turn it up if it's down.
Make sure that in speaker setup, that you have the selection for a sub turned on.
Jun 14, 2009 | Onkyo TX-SR304 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
No Signal on sub preout on my Onkyo TX-SR703 AVR
Well the next step would be to make sure that all the settings are set to subwoofer yes, and set your crossover as well.  The amp usually has a crossover which tells the microprocessor which frequencys to send to the sub.
Jan 06, 2009 | Onkyo TX-SR703 Receiver
No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Dec 16, 2008 | Onkyo TX-SR606 Receiver
Not working until the power switch is toggled
Try turning up the sub output on the onkyo.
Aug 05, 2008 | Velodyne CHT-10 Subwoofer
Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
May 14, 2008 | Onkyo TX-SR304 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Onkyo 805 sub hook up problem
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
Onkyo TX-SR304 Receiver Logo
1,078 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
