Question about Nokia 9500 Communicator
Wireless lan not functioning in my nokia 9500 model
I tried to set up the wireless lan into my phone however, i cannot access the internet even though the wlan is detected already by the phone. i installed a browser opera mini but it cannot access the internet. please help me find a solution
  • 2 more comments
  • Anonymous Apr 09, 2008
    The same problem we are facing of. Please somebody can help on this issue.
    Thanks
  • jimboh69 Aug 10, 2008
    sky internet detected but asks for wlan no
  • Anonymous Aug 17, 2008
    wireless lan not functioning in my nokia 9500
  • Anonymous Mar 28, 2009
    it asks for wlan no.what do i do.any help?
    Problem Solver:
  • 12 Answers
Upgrade the 9500 software / firmware.
Posted on Mar 22, 2008
Nokia 9500 network signal is not working
If the 9500 cannot communicate via WLAN but is getting a connection - do the following:
1 - set up a new Internet Access Point in control panel
2 - use the SSID (WLAN Name) to identify the network
3 - set 'Automatic IP address' to NO (Advanced Settings)
4 - give the device an IP address from the range being used on that network
5 - set 'Automatic DNS' to NO
6 - enter a pair of DNS server IP addresses (from your ISP)
7 - back up the phone settings so you never have to do this again
May 29, 2012 | Nokia 9500 Communicator
I have nokia e5 but whenever i try to use the the phone's vwireless lan to access the internet through my laptop internet connection,it gives me ''invalid server name'' response
i found this website for you, just follow the steps indicated and you can use your phone and your laptop to connect to the internet
*the settings are for nokia e72, but you can use the same settings (the difference may be is the name/options on the contorl panel settings of your nokia e5)
http://www.nokia-mobile-internet.blogspot.com/
Apr 14, 2011 | Nokia E5 Cell Phone
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Cannot get into admin console on wireless router!
Unplug the Nokia when you want to work on Cameo, or hook directly to Cameo, via Ethernet port.
Feb 27, 2010 | Computers & Internet
Nokia 9500 get restart when click Internet Broser / WLAN setting
Your firmware is ANCIENT. If you have installed Nokia PC suite in your PC connect your (fully charged) phone and click on Software update. If don't have it, then go to Nokia web and download it. YOU NEED FIRMWARE UPDATE.
Oct 16, 2009 | Nokia 9500 Communicator
Though it shows network signal excellent does not to the net wort
How is your router set up? Are you using WPA or WEP security? WEP is the newer encryption and I'm affraid 9500 doesn't support this. Would try update firmware and hope that Nokia integrated fix for this in to the update.
Rate me if it helped. Thanks.
Apr 14, 2009 | Nokia 9500 Communicator
Netgear FWG114P Print Sever not functioning on upper level of LAN
if you set your dynalink's dhcp list up to a certain number (example: .1-.99). connect cat5 cable from dynalink lan port, into print server lan port. make sure print server can be setup as access point. if so, turn access point setting to on. make print server static ip address the next number outside of dhcp range (example: .100).
.100 ip address is the port number you should then be printing to, using a tcp/ip port.
if print server can be set up this way, then it now becomes wireless access point for all wireless devices. i am assuming, since you didn't mention it, that the dynalink is NOT wireless. if it is, the the print server just becomes another device on your existig network, taking the place of the network adapter the printer doesn't have. just set it up the same way you would set up another workstation on the network. except, make it static.
Apr 02, 2009 | NetGear FWG114P Router (FWG114PAU)
Wireless
I have 9500 and it does support wireless internet, but many people are having problems with it, so maybe you want to consider other option like E61 or Sony Ericsson P1. I don't actually know how they work, but I've tried 9500 and there are problems.
Jul 02, 2008 | Nokia 9500 Communicator
Modem issues
If you are using wireless, make sure that the password is correct...
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
If not wireless.Unplug your router and modem for a few minutes.Then restart your computer, and plug the router and modem back in...
Jan 11, 2008 | Intel Motherboard
Nokia 9500 Communicator Logo
175 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
