Question about Akai LCT4216 42 in. LCD Television
Akai LCT42Z6TM HD 1080P TV
I am having the same problems as everyone else on this blog. All of the HD resolutions are going out, there are lines going across the screen, blocks of color appear, and it takes forever for the picture to warm up enough for it to be used.
Those capacitors you mentioned:
Are they labeled inside so that i can just change them out?
Are they easy to replace?
Are you sure that thsoe are teh only ones that need replaced?
How do i know where they are at?
The tv you worked on for this is the LCT42Z6TM HD AKAI right?
  • Anonymous Apr 17, 2008
    I am having white horizontal lines running across picture , then screen goes to snow and then scrambled colored cubes .
  • Anonymous Jan 13, 2009
    I had the same issues listed here, white lines, 4 squares, etc. Replaced all three caps listed for $5 and problem solved. The same issue happened on another TV of mine and cost me $240 to get fixed. Thanks for everyones help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 60 Answers
Yes, I am a computer / electronics person and by brother's tv had the same problem, here is a complete description of the problem and the fix. Many thanks to all that have come before
Symptoms
1) While watching tv, there will be vertical grayish lines that move around a bit on the screen
2) While viewing a menu, the menu will be all hacked up as if the bits are all out of order
3) If you unplug all of the sources and then re-power the tv, unplug from wall, the tv will seem it is working fine. Menus will work until a video source (Component) is plugged into the tv.
Tacking the back off
WITH TWO PEOPLE Lay the TV on a table with a blanket, etc to protect the tv. Do not try and move the TV with the back off in general. You may flex the screen and damage it.
Remove all of the screws from the back including the one under the sticker near the left bottom. Remove the stand from the bottom. Lift the back up from the left to the right. Power is hooked to the right of the back. Remove the two screws to remove the power jack from the back.
Remove the back and place aside
Remove the RF cover from and the board will be underneath
Remove all of the screws from the board and from the RCA connectors from the outside bottom of the board.
Carefully remove all of the wires, taking time to remove the glue from the connectors. The glue should "Snap Off", take your time here. Remove the wires, noting where they all are. Take your time with the big connector on the left side.
You will see that all / some of the caps will have a discoloration on the bottom.
Replace and replace ALL of the caps on the upper left side of the board. It's OK to replace with a higher value Voltage, they must be the same uf value of equal or higher voltage. They must be electrolytic caps (+/-). Make sure the line up the - properly with replacing. Radio shack may not have all of the them, but other electronics supply place should. They are call fairly common.
If you have never done this before, find someone that has, or find another tutorial on how to do this. You will need a small soldering iron and solder ****** and very thin solder from Radio Shack.
Replace the board, we tested by putting the board back. Sliding the TV on a table so the top could be seen and then plugging a source in and verifying it worked before reassembly. You HAVE to have a component source plugged in or it will false positive the test. We found this out the hard way....
Replace the back and the screws. On the right side of the TV MAKE SURE that the AC power wires are NOT in the way the screws on the right hand side.
Replace the TV to the original position and test....
Reason for Problem.
Either they have a flaw in the design, but more probably they had a poor supplier of the Capacitors. I have seen this before and we will probably see it again. This really should be some sort of class action suit since they are all failing about 1.5 years of use.
Any question, please contact me....
[email protected]
Jeff Orthober, Assistant Professor, Milwaukee School of Engineering.
Posted on Oct 11, 2008
My suggestion is replace the three bulging caps on the board all in all it will cost you around $12 U.S. to do that. The problematic caps will be obvious as they are most probably bulging and leaking
Posted on Jan 19, 2009
  • 28 Answers
There are 5 caps. and they are surface mount type there ref#'s are C280,C301,C302,C320 andC323. They are 100 MFD @35VDC and they are on the main board. This is service bulletin from factory service manual.
Mike
    Problem Solver:
  • 18 Answers
There are three caps that always pop on that psu board... if you are feeling adventurouse go to radio shack and pick 3 24v 1000mF caps and replace them... that will almost always work otherwise go to megmeet.com and buy a MLT169c if its even still available the original part is mlt168a,b,c but the 169 is interchangable and better quality... for a chineese board... my suggestion is replace the three bulging caps on the board all in all it will cost you around $12 U.S. to do that. The problematic caps will be obvious as they are most probably bulging and leaking... remove them and replace them with the higher voltage ones and it will be fixed and last quite a while longer... (never had one go out after doing this)
Posted on Apr 26, 2008
  • 62 Answers
Yes - the four capacitors that are mentioned are the correct capacitors - call 800-726-4405 to verify the info. akai LCT42z6tm
Posted on Mar 29, 2008
    New Friend:
I had the same problem and I replaced the capacitors on the board. It now works like new. I still can not get the cox cable remote to work with the tv.
Thanks,
Glen Hall, Sr. Tulsa,
[email protected]
Posted on Dec 25, 2009
  • BillFromMEM Feb 06, 2011
    I had this issue, saw it well documented here... even found a video on the repair on YouTube. Finally just bought a 15 dollar soldering iron and four caps off Amazon... took it apart per instructions on this thread. desoldered and removed the old caps, put in the new ones which were 'thicker'... no problem though. Didn't need to add solder, just clipped the leads down to about 1 cm and spread them the same width then heated underneat to drop one leg in, the the other. did that for all four caps. I've never done anything like this but had no problem. The toughest part was geting the wire connectors off without pulling the wire apart... stupid glue. But once I got them off (I also took pics of the wires I unplugged after tagging them with numbers so I knew where they went back to. Also, figuring out which lead was and which was - was tought. But the circuit board is marked UNDERNEATH showing which leg is . Three of the four caps have the leg on the 'upper side' (toward the wire connectors) and the last one is reversed. Be sure to get them right. This worked like a champ and took me two hours total... and I've NEVER done it before. Now the TV is like BRAND SPANKING NEW!
I had the same issue as everyone else here, white lines, 4 squares, etc. I replaced the three caps listed for $5 and problem was solved. The same issue happened on another tx of mine and it ended up costng me $250 to get repaired. Thanks for everyones help on this.
Posted on Jan 13, 2009
SOURCE:
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
I have this akai tv model lct42z6tm and connected to a vcr video output to the video input of the tv.it works for about 2 minutes and suddenly it shows grayish horizontal lines and the it scrambled all...
You may have bad capacitors on the main board where the signal is processed. These caps are as labeled: c280,c323,c302 and c320- replace this one first (it usually fixes the problem) Replace these caps with 100uf @35V
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Akai 42" LCD has lines on start up
    I got the same problem on a LCT42Z6TM. It is related to video, occurs on VGA, S-Video and Video Ports.
    Aug 25, 2007 | Akai LCT4216 42 in. LCD Television
    Akai LCT4216 42 in. LCD Television Logo
    1,391 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
