Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Color convergance t.v. has three color seperation
    Genius:
  • 1,030 Answers
THE akai convergence ic have proabaly blown. stk392's and will have to be replaced
Posted on Mar 18, 2008
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a magnavox projection tv and all three colors seperate on the screen. How do I fix this?
Thats usually a convergence issue. Most phillips and magnavox ear projections use the Phillips DPTV305 - DPTV345 convergence repair kit which contains the parts and the CD with instructions for the repair. The kit is available at www.tvrepairworld.com
May 01, 2011 | Philips Televison & Video
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
Looks like some kind of color seperation
Three d looking etc means a convergence problem.
If you go into the customer menu and select convergence and then advanced look to see if blue or red are skewed and or will NOT adjust in some area.
If this is the case I have start to finish and step by step instructions for this repair that I can post here for you.
Total parts cost will be under 30 dollars from a seller I use on EBAY.
LET me know if you have any questions.
SD TECH
May 21, 2010 | Mitsubishi WS-55905 55" Rear Projection...
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair World.com,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Three colours don't converge
Shrink, the convergence circuit needs to be repaired, Until someone gets in there and takes a few measurements it`s hard to say what the cost will be, may just need to be re-soldered, good luck, BMW Rider
Dec 18, 2007 | RCA P46810LV 46" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Green colors are seperated from rest
You might have a bad green convergence output IC either loose from the circuit board or open internally OR shorted. Stargazer
Apr 22, 2007 | Pioneer PRO-99 TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
