Question about Vacuums
Engine troubles I have a 1975 4x4 GMC full size van. The motor is a 350 cid small block on propane. The thing hadn't been running in 5 years and when I tuned it up I changed vacuum advance pod on HEI distributor and hooked to a better vacuum and now the hotter it gets the faster it idols and when I try and turn the timing back, it starts hard. Wondering if vacuum is too strong or what is up?
I haven't fixed it yet but I think I might have a solution for it. From the factory this thing had a 4 barrel carb and they put an equivalent size atomizer in it for the propane and over the years someone omitted the EGR system in it and propane is already a hot burning fuel so without that system in it it picks up idol speed when under normal operating conditions and when I put the system back in it should fix the problem...... I hope. thanks for quick response. Grant
Posted on Mar 21, 2008
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
It's 5 years old and I vacuum twice a week about 900 sq ft. It is starting to smoke and the belt sounds like it's working overtime. The hose is fine. The bag is continuing to fill up. The floor...
Make sure that the dirt bag is empty and that the motor bearings are good. Also check for any debris that may be gumming up motor bearings and forcing it to run slow.
You also can check out the motor brushes and replace them.
Mar 22, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Carpet beater not turning on, rest of vacuum ok, reset button down
Is the PN motor not working, or just the brush not spinning. If it's the brush, a new belt is needed.
If the motor isn't working, it could be due to several things. Follow the trouble shooting steps below.
1. Check all connections from hose handle to PN for discoloration. Any parts showing discoloration or melted plastic need to be replaced.
2. Attach PN directly to the hose. If the motor works, there's a problem in the wand wiring/connections.
3. Attach the Sidekick directly to the hose. If it works, but the full sized PN doesn't, there's a problem in the PN. Problems could include: wiring, connections, bad motor, bad switch.
4. If neither Sidekick nor PN work, the problem is likely in the hose. Potential problems include: bad wiring, connections, or bad switch.
5. You can try another hose known to be good to test the PN. If it still doesn't work, the problem could be in the canister itself.
I strongly recommend taking it to an authorized Aerus Electrolux store for diagnosis and repair if needed.
http://www.aerushome.com/storelocator/
Apr 09, 2011 | Electrolux Epic 6500 Vacuum
We have a Kenmore Progressive Model 116 Upright bagged vacuum with Hepa filter. It's at least a couple years old. For quite some time now when ever we use the vacuum the vacuum motor will shut off nafter...
I suspect that you have a restriction. The motor sounds like the thermal break is stopping the motor before damage, due to heat.
You must witness that the entire suction and discharge side are clear. This is not always very easy, but necessary. I bet that you find something blocking somewhere...
Nov 13, 2010 | Kenmore 34612 Bagged Upright Vacuum
Dyson runs about 5 min then shuts off
REMOVE AND CLEAN FILTERS AND YOU MAY FIND IT WILL WORK OK IF STILL CUTS OUT YOU MAY HAVE A FAULTY THERMAL CUT OUT BLOCK INSIDE THE MOTOR HOUSING
THIS HAPENS WHEN DYSON IS USED WITH CLOGGED FILTERS AND HEAT DAMAGE TO THERMAL BLOCK
AVERAGE REPAIR COST £45 - £ 69 FOR NEW REPLACEMENT
Jul 11, 2010 | Dyson DC14 Full Gear Bagless Upright...
I need the fuel/gas mixture for a small (12") McCulloch Chain Saw. It has a 2.0 C.I.D. label with Fuel Mix I lnoted at the fuel cap. ja
The 2.0 CID is Cubic Inch Displacement, the size of your motor. As for fuel mixture, generally a 50:1 is a benchmark for this. Typically, it should be 1 gal. of gas for 2.56 oz. of two stroke oil. They sell pre-packaged, pre-measured oil at your local DIY shop or lawn mower repair shop.
Jan 18, 2010 | McCulloch MC1275 Steam Vacuum
Hello, I have a problem with my Eureka Powerline bagged upright vacuum. It has a 12 amp motor and is model #4352, Type D. It was probably bought new in 1998. My problem is, while vacuuming today the motor...
it sounds like a rubber sealing in the motor has come loose and is being constantly rubbed against the walls of the motor with would cause the smell and loss of motor speed caused by the fricton of rubber against the rod so if you can get to the motor try to open it and see if you can get it if not take it to a small engine repair service hope this was helpful:)
Nov 16, 2009 | Vacuums
Aerus Model 152C- vacuum doesn't run
it probably does think you have a full bag.make sure you have it cleaned out and has a bag in there or it might be the sensor for the vacuum and is not working properly. contact your nearest electrolux vac store.or you are not using proper bags.
Jun 28, 2009 | Electrolux Vacuums
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
