Asus notebook my asus notebook power supply is not working properly.
    President:
  • 778 Answers
Redy,
With the model number of your Notebook, you'll be able to find a replacement for your power supply at various auction sites, after market parts supply shops, and even the OEM power supply from the manufacturer. You can check for proper output voltage with a multi-meter or have someone check it for you.
Just make sure that the power supply is at fault and not the DC jack on the MoBo. If it is the DC jack (very common problem as people transporting their Notebooks/Laptops with the P.S. plugged in and the connector gets knocked around damaging the DC jack), that will require replacing the jack (above average soldering skills or an electronics shop will be required), and more than likely the Manufacturer will only offer MoBo replacement only for bad DC jacks. You should be able to determine if the jack is at fault if you can manipulate the male power connector of the power supply and that gives you power intermittently, or even maintains in a certain position once manipulated.
Good luck.
Posted on Mar 18, 2008
Get a new power supply which works properly
SOURCE:
My notebook shows no sign of power
Remove battery turn the notebook on, does it works?
press the battery back in place, is there any lock on backside op the notebook?
is there any signs of charging? flashing led or so?
if not the internal plug to the power supply could be damaged.
Mar 24, 2016 | ASUS X200CA Black 11.6" Notebook 1.5 GHz...
ASUS Eee PC Seashell series notebook will power up for a second and then go out
Remove the main battery and try again, have the power supply charger checked to make sure it is working properly, if okay the DC jack in the laptop is a common source of trouble. The unit will need to be taken apart to assess the motherboard.
Jun 03, 2012 | ASUS Eee PC 1015PEMMU17RD 101 LED Netbook...
I havy my ASUS K40IN,,my problem is about powering it up,,i'm having trouble of opening up ,i always press the power button very hard,but it takes me time before opening,sometimes when lucky its e
It is possible you have a intermittent power on/off button that is not working properly, remove main battery to see if that will help, if not! unplug power supply from laptop and remove main battery, next press and hold power for 2 minutes to get rid of any residual voltage, now put everything back together and power up.
May 06, 2012 | ASUS K40IN Notebook
Asus P5 GC-MX Board proccessor does not get power what parts should be changed
First, check if the connection from the power supply to the motherboard is properly inserted. If it's loose, that may be whats causing you to receive no power from the supply. Check the wall socket to make sure it works, as well as checking if everything is plugged in properly. If you are still getting no power, then it maybe time to buy a new power supply. If there is some indicator of power to the mother board , such as an LED or light that turns on when plugged in, there may be a problem with your power switch.
Mar 29, 2011 | ASUS P4PE-X Motherboard
ASUS laptop;Windows-XP installation plagued by numerous problems;a broken LAN-connection symbol is there --> Network cable disconnected.But the connection is there!
I am sorry but you will get untold problems as this notebook was designed for newer OS than XP.
XP doen't contain the required drivers and won't work properly.
Re install the OS that was supplied and then download the drivers from Asus.com
Jan 09, 2011 | ASUS Eee 4G Notebook
Hello there, I got Asus PC-DL Deluxe UAYZ motherboard and would like to connect to ATX 300W 20 pin power supply. Do you think it works, or should i wait till i find 24pin power supply. thanks for your...
This motherboard is designed to be used as a workstation or server. This mother board will need a specific power supply designed for this board as it can use 2 Xeon CPUs. Setting this board with the incorrect power supply will cause the system to not power up or at worse result in damage to the CPU, motherboard, memory, video and other devices including possibly the power supply. I suggest obtaining the proper power supply for this motherboard
The manual for this board states that the motherboard requires a 24 pin ATX power supply that also has an 8 pin 12 volt connector. The manual from ASUS recommends no less then a 300 Watt power supply. I would professionally recommend 500 watts or more if the system will use 2 CPUs and many hard drives in a RAID array.
A suitable power supply can be found here at Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16817163111
The manual is here at ASUS's support site at http://support.asus.com/
Feb 24, 2010 | ASUS PC-DL Deluxe (90-MSV290-G0UAY)...
Asus dont turn on
try this
1st. turn off laptop
2nd. unplug power supply
3rd. remove battery
4th. let stand with out any power for about one min
5th. put battery back on
6th. place the power supply back in
7th. turn computer back on.
Should work!!!!!!!!!!!! Good Luck!
Jan 25, 2009 | ASUS Eee PC 900 16G Notebook
Asus Premium Vista M2n32-Sli
Dear Riddler2002,
First thing u have to check the SMPS if it is not working properly then it will restart automatically not working properly it means that the SMPS not giving the excact power supply to mother board now the question is how can u check the SMPS working fine or not do one thing borrow a SMPS through u r friend connect that SMPS to u system if it working with u r friends SMPS then u have to change u r SMPS if still u r getting same problem then u have to check u r system RAM if RAM not work Properly then it will get this type of problem so Change the RAM and connect another RAM to u r system if the RAM is working fine then it will work properly.
Regards,
Bittu_8
Feb 13, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Computers & Internet Logo
87 people viewed this question
Ekse
Alun Cox
