Question about Lexmark X5470 All-In-One InkJet Printer
Can not scan
Lexmark X5495 continues to read "Unable to retreive application list" I tried unplugging printer waited 30 seconds but nothing changed. I checked security and made sure anything that said "Lexmark" was an "exception". I am lost! Can you help me out please? Any assistance would be very much appreciated.
Thanks!
BGM
Uninstall the drivers and utilities, then reinstall from lexmark website.
Posted on Apr 01, 2008
SOURCE:
When i scan to computer it cannot download the application
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 26, 2012 | Lexmark X5650 ALL-IN-ONE PRINTER
Trying to scan, says "cannot retreive application
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/dbCiI6. Select your operating system, download and execute the file.
Oct 27, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hi, I have lexmark printer, model X5495, and I am having problem with the machine. The alignment is on, and whenever I tried to make copies, the paper is all cramped up and got stuck. I cannot find my...
Try removing the cartridges from the printer. Close the cover. Remove the sheets of paper. Unplug the printer from the power source. Replug after 30 seconds. When the printer's ready, reload the cartridges. Load some paper, don't overload. Try printing again. If problem continues, I strongly suggest you contact Lexmark technical support to further investigate the problem. You may be having a hardware problem.
Here's the link for the Lexmark X5495 User's Guide: http://bit.ly/c5QWkq. Just download it and it's for free. Thank you for choosing Lexmark.
Aug 25, 2010 | Lexmark X5495 Printer
Cannot retrieve applications listo lexmark 3500
my printer will not scan when i try it tells me downloading applications list then it will not download it tells me cannot retreive applications lists and i have reinstalled the disc and still nothing
Jan 27, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmar X5410 - scaner
Does scanning work when initiated from the computer using either the "Imaging Studio" or "Productivity Studio" software that came with the printer ?.
Here's the link to the user guide:
http://www.lexmark.com/publications/pdfs/2007/5410/v8760668_en.pdf
Goto to page 69 for help with scanning.
Hope this helps !
Mar 30, 2009 | Lexmark X5495 Printer
Unable to scan
scan from within the software that you're going to use to edit the file.
Jan 01, 2009 | Lexmark Office Equipment & Supplies
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' -----> 'From scanner or camera' (while the Lexmark is in scan mode). Just tried it and it really works.
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Scanning with my printer
No its seem to be some software clashed problem! Try to remove your old software and then try to clean registry and then install again then it should work!
Dec 08, 2007 | Computers & Internet
Lexmark X5470 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
